Page 5 of 5
Re: Economical 8.33 kHz Radios
PostPosted:Tue Feb 14, 2017 2:49 pm
by Ridders
Highland Park wrote:For those of you who've had an 8.33 radio fitted only, not part of any other refit and not a permit aircraft, out of curiosity how much has the installation cost?
Second hand re-con nav/com/gps = £3800 +vampire. I wanted a certified GPS to replace the one I did have installed. I also had Mode S and Intercom fitted, a load of old stuff ripped out plus new panel work and a new garmin G1106 indicator. Labour costs are pretty variable, obviously thats the bit you can not estimate that well, but usually the avionics shops will estimate time for wiring looms, fitting the parts in, cables, plugs, screws, etc. 10hrs upwards I guess, the quotes I got the labour rates were about 45+ per hr so 500 +vamp, or more for labour.
In my view whats important is to go to someone with personal recommendation and perhaps who's work you have seen.
Get a few quotes.
PostPosted:Tue Feb 14, 2017 4:47 pm
by Paul_Sengupta
Ridders wrote:£3800 +vampire.
dH?
PostPosted:Tue Feb 14, 2017 8:43 pm
by muffin
Why oh why did they not go to 12.5 kHz spacing like the rest of the VHF band? Assuming it was ever necessary to change anyway. Nigel would never have allowed it!
PostPosted:Fri Feb 17, 2017 9:44 am
by muffin
I have just been quoted £960 labour to remove the existing Bendix King Nav com and replace it with a TY96 com only. I would be quite happy to do it myself but as its a certified aircraft I can't.
PostPosted:Fri Feb 17, 2017 11:26 am
by Paul_Sengupta
You can, you just need someone qualified to sign it off.
PostPosted:Fri Feb 17, 2017 11:33 am
by Bathman
Which you can never get anyone to do. Turkeys don't vote for Christmas.
PostPosted:Fri Feb 17, 2017 11:47 am
by cockney steve
Someone who's snowed-out anyway, may well be happy to take a £ 50 token of appreciation for 20 minutes work.......one assumes the removal is straightforward...so, inspection of visible wiring, re-inspect new connections test after mounting in panel.
even a £150 bung would be a good deal for both parties.
PostPosted:Fri Feb 17, 2017 11:51 am
by riverrock
You forgot about the paperwork CS.
PostPosted:Fri Feb 17, 2017 11:58 am
by trapdoor
Think the labour and certification element on the new GTR225A to directly replace the 'Clockwork Narco' is around £1200 + VAT which includes the sundries but not a new antenna if needed.
That will give me the 8.33 as box 2 with the old 25kHz Garmin GPS/Com staying as box 1 - if I had opted to have the boxes 'swapped' around to make the new 8.33 radio box 1 it would have added between £300 and £500! Seems a lot of dosh just for a 'renumbering' exercise.
PostPosted:Fri Feb 17, 2017 10:37 pm
by cockney steve
Well spotted
Riverrock so, that'll be another hour and a half then
PostPosted:Fri Feb 17, 2017 10:57 pm
by wigglyamp
riverrock wrote:You forgot about the paperwork CS.
There is no certification paperwork cost if installing a Garmin GNC/GTR in an EASA aircraft. There is a free-to-use minor change on the Garmin dealer website, produced by Gama Aviation.
PostPosted:Sat Feb 18, 2017 7:29 pm
by riverrock
I was being tongue in cheek since I've got a permit...
However does there not need to be POH updates (or does it just say "see radio manual) and a W&B update?
PostPosted:Sat Feb 18, 2017 9:11 pm
by Charliesixtysix
If on LAA permit you will need to submit a MOD 7 and associated LAA-FT/Avionics flight test report.
