Fri Jan 20, 2017 9:18 pm
#1513765
I know of a homebuilt aircraft that was ordered to be reduced to component parts, the individual parts re-inspected, and then assembly could be permitted to start again. This was partly because an inspector (soon to be ex-inspector) took money to build it, and partly because it was so full of faults it was dangerous. (I still have the photos somewhere, as I was brought in to do a duplicate inspection on the beastie.)
Which sort of makes the point - if you build it for yourself, you will pay attention, as it'll be your little pink body leaving the ground in it. And that is at the root of the rule that says that either you can build (at least 51% of ) it under LAA or BMAA supervision at relatively low cost and oversight, or you have a CAA approved factory with regular audits.
There are UK microlight manufacturers, and if you're prepared to pay, they'll do a certain amount of customisation.
There's a second hand market, and BMAA or LAA will handle mods for you. Frankly, I wouldn't encourage putting mods through on a CofA aeroplane unless you are a good chartered aeronautical engineer with a lot of initial airworthiness experience.
Badger - if you can accept a 2-seater, there are modern 3-axis microlights which will tick all of your other boxes, is available new and factory built, and I'm sure that the various manufacturers would be delighted to customise decor, instruments, and suchlike for you.
