Thursday 23 May 2013 04:48 UTC
Latest FLYER headlines:
More news
Spinner replacement
Forum rules
davey
Sad Forumite
Spinner replacement
Postby davey » Thu Oct 04, 2012 9:03 am
Can you replace the spinner on a Cof A aircraft yourself or does it need and engineers involvement ? Just looking at it it seems a very easy swap, remove machine screws, fit spinner, replace screws with a dab of locking fluid, or am I missing something.
Sometimes you're the pigeon and sometimes you're the statue...........
Delta Juliet
Sad Forumite
Postby Delta Juliet » Thu Oct 04, 2012 9:17 am
Yes.... paying lots of money
LKI Chief grasscutter (retired).
If everything's under control, you're going too slow.... Mario Andretti
Monocock
Lost Cause
Postby Monocock » Thu Oct 04, 2012 9:47 am
JFDI.
Who's gonna know?
Skyhawk-N
Needs Help
Postby Skyhawk-N » Thu Oct 04, 2012 4:01 pm
golfcharlie
Forumite
Re: Spinner replacement
Postby golfcharlie » Thu Oct 04, 2012 5:15 pm
If you have the right tools, locking wire etc., no practical problem. But you may have to remove the prop to fit a backplate; depends upon the design. Then you require: the right paperwork for like for like replacement; an understanding engineer prepared to release the replacement to service (sign); and check the correct tracking. Torque spanner required. Not a difficult job. But gotta be correct, or else....
Ben
Sad Forumite
Postby Ben » Sat Oct 06, 2012 5:36 pm
golfcharlie wrote: But you may have to remove the prop to fit a backplate; depends upon the design. Then you require: the right paperwork for like for like replacement; an understanding engineer prepared to release the replacement to service (sign); and check the correct tracking. Torque spanner required. Not a difficult job. But gotta be correct, or else....
Why there is a need to remove the prop if one removes old type X spinner in order to install new type X spinner? Your statement makes no sense, maybe a new engine at the same time?
Davey
Get the spinner that you need to replace the old one and do it yourself.
Ben
golfcharlie
Forumite
Postby golfcharlie » Sat Oct 06, 2012 6:08 pm
Because the replacement spinner will probably not be pre-drilled. The replaement sppinner may be supplied with a different backplate, or one with different fixtures. Also, the replacement may not necessarily be supplied with the cut-outs for the blades. These are not simple tasks. It all depends on the installation, and the condition of the replacement parts. You will be lucky if it is a 'plug & play' job. It rarely is without a hidden tripwire.
Colin G
Aviation Junkie
Postby Colin G » Sat Oct 06, 2012 8:21 pm
golfcharlie wrote:Because the replacement spinner will probably not be pre-drilled. The replaement sppinner may be supplied with a different backplate, or one with different fixtures. Also, the replacement may not necessarily be supplied with the cut-outs for the blades. These are not simple tasks. It all depends on the installation, and the condition of the replacement parts. You will be lucky if it is a 'plug & play' job. It rarely is without a hidden tripwire.
Yet to find one not pre drilled and shaped for the prop. A replacement spinner will be designed to fit on the original backplate. That's why it's a replacement and not a retrofit.
Remove screws holding spinner to backplate, remove spinner, fit new spinner, reinstall the screws and tighten them. SIMPLES!!
"You can make things happen, watch things happen or wonder what the **** happened"
Skyhawk-N
Needs Help
Postby Skyhawk-N » Sat Oct 06, 2012 10:44 pm
peterh337
Postby peterh337 » Sat Oct 06, 2012 11:00 pm
Removing and replacing the spinner has to be within pilot maintenance privileges, not least because one needs to remove it to remove the lower cowling on certain aircraft types.
www.euroga.org
FAA CPL/IR
JAA PPL/IR
Colin G
Aviation Junkie
Postby Colin G » Sat Oct 06, 2012 11:50 pm
Skyhawk-N wrote:...and the logbook entry?
Spinner removed. Replaced with new spinner, part number XXXXX. Refitted and secured in accordance with manufacturers procedures. Signed, A. Pilot (who owns the aircraft)
Return to Technical Discussion
Who is online
click here Login / Register
