Tuesday 21 May 2013 07:48 UTC
Latest FLYER headlines:
Major windfarm proposal threatens Popham  -  Manx Aero Club ends operations at Ronaldsway   -  Stapleford's new circuit pattern for twins
More news
Dyn-Aero to Perth...shepherded into Glasgow
Fisbangwollop
Forumite
Postby Fisbangwollop » Mon Jun 11, 2012 4:32 pm
Check out my post on PPRUNE regarding "Listening to ATC advice"...maybe if he had taken note of the constant weather updates I had given him whilst still VFR and a fair distance away he may have come up with an alternative plan!!
Private Jet
Forumite
Postby Private Jet » Mon Jun 11, 2012 7:34 pm
Don't Overfill - without giving too much away, that was a tourist heading North rather than a local returning to base wasn't it?
gyrotyro
Forumite
Compass broken?
Postby gyrotyro » Tue Jun 12, 2012 6:10 am
An LAA permit aircraft is required to have a back up compass such as a liquid filled or card compass type. So suffering a total electrical failure would not effect the pilots ability to know which direction they are flying in.
More to this than meets the eye.
Glad he made it down safely though.
Composed mostly of water and ginger biscuits.
PortAndCheese
Forumite
Postby PortAndCheese » Tue Jun 12, 2012 6:29 am
He could have been VFR-on-top of a solid layer of cloud, no?
Still, I would have thought the aircraft battery should have been enough to cover an alternator failure.
gfry
Sad Forumite
Postby gfry » Tue Jun 12, 2012 10:04 am
PortAndCheese wrote:He could have been VFR-on-top of a solid layer of cloud, no?
No not legally.
1) The pilot would need a minimum of an IMC rating (which they may well have).
2) The aircraft needs to be certified for IMC flight, which it is not.
Blah Blah Blah
stevelup
Needs Help
Postby stevelup » Tue Jun 12, 2012 10:09 am
No not legally.
Are you sure?
1) Is no longer true due to the EASA rule changes, and that invalidates your point 2) as VFR on top isn't IMC?
gfry
Sad Forumite
Postby gfry » Tue Jun 12, 2012 10:16 am
stevelup wrote:
No not legally.
Are you sure?
Has the CAA done away with the UK slant on VMC on top then? if so then my point 1 is not valid. For my point 2, unless you find a whole you cant get VMC on top without going IMC.....so my point 2 is sort of valid.
Blah Blah Blah
stevelup
Needs Help
Postby stevelup » Tue Jun 12, 2012 10:22 am
gfry wrote:Has the CAA done away with the UK slant on VMC on top then? if so then my point 1 is not valid.
Yep. VFR on top is now permitted without an IMCR or IR.
Of course - and in the circumstances related to this thread, clearly your point is 100% valid.
Paul_Sengupta
Season Ticket Holder
Postby Paul_Sengupta » Tue Jun 12, 2012 11:04 am
gfry wrote:unless you find a whole
A whole hole? :D
stevelup wrote:Yep. VFR on top is now permitted without an IMCR or IR.
Only if you have a JAA/EASA licence. If you have an old CAA lifetime one, or, I guess, NPPL, then you're not permitted as I understand it.
gfry
Sad Forumite
Postby gfry » Tue Jun 12, 2012 11:07 am
Learn somthing new everyday. Thanks
Blah Blah Blah
PortAndCheese
Forumite
Postby PortAndCheese » Tue Jun 12, 2012 11:15 am
My understanding was that with an IMC or IR, a pilot flying VFR in VMC is excused the requirement to remain in sight of the surface. As we don't know the credentials, it's possible that the pilot was adequately qualified.
The aircraft (MCR-01) is not certified for IMC, but no-one's suggesting he was IMC. The aircraft is pretty quick, so he could have covered different weather systems.
It seems the aircraft was making quite a lengthy transit returning to base, so it's not impossible that he popped up through scattered/broken cloud in the Midlands (for example) and then proceeded North over gradually thickening cloud.
Speculation: alternator failure, and battery only going to give ~30mins, not enough to fly to a cloud break and descend, so rather than fly MDR and bust Glasgow/Edinburgh airspace he made the best choice and called for assistance. Alternatively theories probably exist too, and every pilot will have their own comfort zone regarding continuing over poor en-route weather.
Paul_Sengupta
Postby Paul_Sengupta » Tue Jun 12, 2012 11:45 am
Replying to my own post here, I will add the caveat..."without an IMC rating". Though I don't think you can get one of those on an NPPL... ;)
Timothy
CLEAR PROPS!!!
Postby Timothy » Tue Jun 12, 2012 11:53 am
It is important to trot out the old chestnut about flight rules being utterly different from licence privileges.
VFR on top is perfectly legal, so long as you are 1000' above the tops, or 1500m horizontally from cloud, and not in Class A airspace, VMC/VFR is perfectly legal.
It is the qualifications you need to be there which are being changed by SERA.
Timothy
Not sent from my iPad.
gfry
Sad Forumite
Postby gfry » Tue Jun 12, 2012 12:03 pm
Timothy wrote:It is important to trot out the old chestnut about flight rules being utterly different from licence privileges.
That made it as clear as mud.
It used to be:
VMC on top with a vanilla JAR PPL was permitted, execpt for those with a UK CAA issued JAA license who had to have an IMC to be allowed toget there regardless of finding a hole or not.
The recent EASA changes (hear say) have removed the UK CAA restriction for VMC on top for UK CAA issued JAR/EASA issued PPL's.
According to VFR flight rules for the UK you had to remain insight of the ground, therefore VMC on top is not legal regardless of the 1000' and 1500m rules.
So....
Are/have the rules been changed to allow VMC on top for UK CAA issued JAR/EASA PPL license holders without an IMC or IR ticket? if so are the VFR flight rules for the UK going to be updated to remove the "insight of the ground" rule?
Blah Blah Blah
chrisdr221
Forumite
Postby chrisdr221 » Tue Jun 12, 2012 12:24 pm
If that Sun photo is genuine, did the police heli need to fly so close, I wouldn't want a big heli up my chuff in my little aeroplane.
PreviousNext
Return to GA Discussion
Who is online
Users browsing this forum: A22_Driver, baldwinm, Bing [Bot], Google [Bot], kestrel539, TG6 and 17 guests
click here Login / Register
