Latest FLYER headlines: Schneider Trophy Air Race celebrates 100 years - HIAL passenger numbers up by 8,000 - First production version of Great Lakes biplane More news
stevelup
- Lost Cause
by stevelup » Fri May 18, 2012 8:28 pm
The desktop version can, and they are very good.
PHENOMENOUS DANGEROUSNESS
peterh337
by peterh337 » Fri May 18, 2012 8:33 pm
I mean generate the sequence of charts automatically, with a slight overlap.
stevelup
- Lost Cause
by stevelup » Fri May 18, 2012 8:47 pm
Yep - it will output a sequence of charts with one click that covers your route.
Tim Dawson
- SkyDemon developer
by Tim Dawson » Fri May 18, 2012 11:13 pm
SkyDemon for iPad 2.3.4 is back in the App Store where it belongs. Here's a list of the new stuff in this build.
The DI instrument can now be dragged out to produce the HSI/ILS instrument, or collapsed to produce the course correction indicator Airspace boundaries are now intelligently merged so only the extremities of controlled and dangerous airspace are highlighted Analysis virtual radar is now enabled, for vertical inspection of track logs User waypoints can now be imported in bulk to SkyDemon for iPad using iTunes file sharing Aircraft definitions not in the aircraft library can now easily be added to the library when editing Aircraft definitions are now stored in the Documents folder for easier sharing with desktop computers running SkyDemon NOTAM are now saved permanently in case of application restart without internet connection
Aussie Andy
- Forumite
by Aussie Andy » Fri May 18, 2012 11:28 pm
You are amazing Tim... bug reported when I woke up this morning, and now have downloaded the fix and can confirm all is well ahead of tomorrow's planned flying  garmin / jeppesen can't do that
peterlondon
- Forumite
by peterlondon » Sat May 19, 2012 12:37 am
Full marks to Tim and team for fixing the problem and getting the update approved by Apple in 24 hours. Great product and a great team supporting it. I flew today and love the new HSI as well as vertical breadcrumb tracklog feature
Aussie Andy
- Forumite
by Aussie Andy » Sat May 19, 2012 6:18 am
Oh yeah, yes I like the vertical breadcrumb tracking as well!
Would lie to understandte new iTunes file xfer better: how does that work?
JonBoy
- Forumite
by JonBoy » Sat May 19, 2012 7:32 am
Well done - amazingly quick bug fix - great service on a truly great product! Tiny little thing I noticed on mine - playing with the simulator mode and the new HSI (which is great by the way!) - when playing with a previously saved route the course deviation indicator on the HSI works fine. When using a route that I've just created to use but not yet saved the CDI does not indicate correctly. Anyone else get this?? (Dunno if this would be the same in real navigation mode rather than the sim - not tried it yet!)
by Mick Sturridge » Sat May 19, 2012 9:41 am
The updated version looks great. All yesterday's problems fixed. Love the HSI.
Who knows how to get the userwaypoints in? Copying them onto the iPad via iTunes is straightforward and the userwaypoints.XML file appears on the iPad. However, when I start Skydemon on the iPad it seems to delete the file and I don't see the waypoints I had on the PC. Please can someone tell me what I'm doing wrong? Thanks.
GraemeH
- Junior Forumite
by GraemeH » Sat May 19, 2012 11:25 am
Hi Tim,
Got the latest iPad version and current maps - the Isle of Man seems to have disappeared! Roads and aerodata are still there but no coastline or terrain.
--Graeme
PaulB
- Beyond Hope
by PaulB » Sat May 19, 2012 11:58 am
GraemeH wrote:Got the latest iPad version and current maps - the Isle of Man seems to have disappeared! Roads and aerodata are still there but no coastline or terrain.
I have coastline and terrain....
Paul
GraemeH
- Junior Forumite
by GraemeH » Sat May 19, 2012 1:31 pm
Thanks Paul,
I went back into the charts updater and the UK was still showing an update was needed, so maybe there was an error this morning when I updated UK and Ireland (Ireland was up to date this time)
Looks fine now after updating.
Timothy
- CLEAR PROPS!!!
by Timothy » Sat May 19, 2012 2:32 pm
It may not be immediately obvious that the HSI/ILS can be resized by pinching. Also, to enable glideslope, you need to go into Setup/Navigation Options.
The ILS function is very nifty if used with caution. My fear is that it will be used by some without enough caution. I guess the same can be said for any tool.
Timothy Not sent from my iPad.
GrahamB
- Needs Help
by GrahamB » Sat May 19, 2012 4:39 pm
Thanks for the rapid fix, Tim (D).
GrahamB
Sent from my high horse
simon_gci
- Forumite
by simon_gci » Sat May 19, 2012 6:27 pm
Another thanks for the quick fix, excellent backup.
Return to GA Discussion
Who is online
Users browsing this forum: Bing [Bot], bogopper, oldbiggincfi, Race200 and 20 guests
Login / Register
