Friday 24 May 2013 07:47 UTC
Latest FLYER headlines:
More news
Total Avgas UL91 UK launch
Wide-Body
Forumite
Postby Wide-Body » Mon Nov 21, 2011 11:29 am
Yak 52 owners. It looks like after a good trawl through the owners, that 91 ul is suitable for the M14P.
Noveau Aero Pikey
peterh337
Postby peterh337 » Mon Nov 21, 2011 11:57 am
Many thanks Hogster :thumleft:
I have forgotten who you are - can't keep track of forum nicknames :)
I've updated my TB20 writeup, under "Unleaded Fuel?"
http://www.peter2000.co.uk/aviation/tb2 ... index.html
This is a very welcome development.
www.euroga.org
FAA CPL/IR
JAA PPL/IR
Rich T
Lost in Airspace
Postby Rich T » Mon Nov 21, 2011 12:05 pm
I think I emailed you using my real name, Rich Tebb.
peterh337
Postby peterh337 » Mon Nov 21, 2011 1:06 pm
OK :)
I wonder what the storage life of this new stuff is?
I am thinking of not only bowsers but also fuel supplied in drums, which quite a lot of people do in the more southern parts of Europe.
www.euroga.org
FAA CPL/IR
JAA PPL/IR
Rich T
Lost in Airspace
Postby Rich T » Mon Nov 21, 2011 2:57 pm
For reference, the EASA SIB that relates to use of UL91 can be found here.
Rod1
Forum Addict
Re: Total Avgas UL91 UK launch
Postby Rod1 » Tue Nov 22, 2011 9:37 am
The fuel is the same as 100LL but without the lead added. I think the mags are saying 6 month shelf life.
Rod1
The Mauler
Forumite
Postby The Mauler » Tue Nov 22, 2011 6:18 pm
What people are missing is the type of valves fitted.
The O-235L2c, in 1 152 may need lead to lubricate the valves.
PaulB
Beyond Hope
Postby PaulB » Tue Nov 22, 2011 8:33 pm
This link show my aircraft engine fuel requirement as 80. Does that mean 91 UL is OK? (O-320-E2A)
Sorry for the thick question!
P.
Paul
Rich T
Lost in Airspace
Postby Rich T » Tue Nov 22, 2011 8:49 pm
PaulB wrote:This link show my aircraft engine fuel requirement as 80. Does that mean 91 UL is OK? (O-320-E2A)
That link is to a 2004 document. Service Instruction 1070 (in the other link) is dated July 16, 2010. I'd be fairly confident that the more recent document supersedes the old one.
Rod1
Forum Addict
Postby Rod1 » Tue Dec 13, 2011 6:57 pm
From the Total Web site;
Avgas unleaded UL91 – NEW !!! UL91 is an unleaded Avgas which is specifically designed for the Ultralight aircraft. It is manufactured by AIR TOTAL and endorsed by Rotax. It can replace Avgas 100LL in a growing number of engine / aircraft combinations http://www.caa.co.uk/. It can also be used in place of mogas (forecourt petrol) which is not an approved Air Total aviation fuel.
On the airfield UL91 complements Avgas 100LL which is still required by some high powered piston engines.
Rod1
Forum Addict
Postby Rod1 » Thu Jan 05, 2012 4:00 pm
Total are apparently very pleased with the number of airfields taking 91UL. By the end of Feb it is expected to be up to 15. I have asked for a list and will add it when it appears.
Rod1
Dave Phillips
Nice wife...
Postby Dave Phillips » Thu Jan 05, 2012 4:09 pm
I've asked them to give me it and they have yet to respond!
Fly Safely
FE(A), PPL(H)
Ian Melville
Needs Help
Postby Ian Melville » Thu Jan 05, 2012 4:27 pm
Dave Phillips wrote:I've asked them to give me it and they have yet to respond!
Perhaps it would help to offer to pay something for it :D
AlanB
Lost Cause
Postby AlanB » Thu Jan 05, 2012 4:43 pm
our engine, TO-360-C1A6D is listed as 100LL....Does this mean there is no chance to run UL91 in it? (I am a bit confused as to what can and can't run 91UL)...
TIA
010000000010001000100010
AlanB
Lost Cause
Postby AlanB » Thu Jan 05, 2012 4:47 pm
belay that, I have found the links above ;)
Actually, how do I use this document?
PreviousNext
Return to GA Discussion
Who is online
Users browsing this forum: Bartonflyer, carlmeek, Cumulo-nimbus, Dave Phillips, dont overfill, Google [Bot], JAFO, lobstaboy, matspart3, Monolo, Mutley, pilotbarry, Straight'n'Level, WingsOfADove and 18 guests
click here Login / Register
