Sat Aug 08, 2015 3:44 pm
#1394631
Bose A20 Aviation Headset Helicopter with Bluetooth
Top spec headset, brand new and never used! RRP £795 on Bose website
This Headset has Bose Warranty remaining!
This is the top model A20 headset as it includes Bluetooth for phone connectivity.
Please ask if you have any questions or require photos.
Grab a Bargain! £600 + postage
The brand new A20 Aviation Headset is Bose's most advanced pilot headset yet. Its breakthrough innovations reduce more noise and provide even greater comfort than previous models, without compromising the clear audio you expect from Bose.
Enjoy a quieter flight - proprietary technologies in the A20 aviation headset reduce more noise than ever before, across the full spectrum of human hearing, in even louder environments. Advanced electronics now use microphones both inside and outside each earcup to sense and reduce more ambient sound. Improved Bose ear cushion technology helps further reduce unwanted noise. New cushion materials block more sound before it enters the earcups, providing an even quieter headset experience.
And even greater comfort - the A20 aviation headset also provides a new level of comfort and stability. The overall headset profile is more compact, but the earcup cavity has been enlarged to allow more room for the ears. These proprietary cushions improve the earcups' acoustic seals, even over eye glasses, and remain comfortable during long flights. The solid magnesium headband is extremely durable, yet lightweight, and its sheepskin cushion eliminates hot spots. All these improvements have been achieved without increasing the headset's weight or clamping force. The A20 headset weighs just 12 ounces and exerts significantly less clamping force than most active headsets.
AUX IN convenience - the redesigned control module now includes an auxiliary audio input with Intercom/AUX priority switching. Many pilots will want to use this input for dedicated GPS and traffic warning systems. You can set audio priority to mute the AUX input completely when intercom signal is detected, or to simply lower the AUX volume appropriately.
Smart power control - the power system in the A20 aviation headset includes a smart shutoff feature that helps provide at least 45 hours of use from just two AA alkaline batteries. With the installed version of the headset, the technology intelligently switches from aircraft power to battery power as needed.
This version is the Bose A20 (with Bluetooth).
Dimensions
Height: 21.40 cm
Width: 16.10 cm
Depth: 8.00 cm
Weight: 340.00 grams
In the box
Included items
A20® Aviation Headset with Bluetooth
In-line clothing clip
Control module
Aux-in cable adapter
Carrying case
Dimensions
Height: 21.40 cm
Width: 16.10 cm
Depth: 8.00 cm
In the box
Included items
Control module
Carrying case
