Tue Mar 17, 2015 3:17 am
#1360513
Qty 6 prop bolts. These bolts are brand new, as delivered by LAS Aerospace recently and still in their packet. They are 8mm thread x 90mm overall long, grip length 65mm, with drilled heads for wire locking. A copy of the original Certificate of Conformance will be supplied with them. No longer required for my build project, they cost £43.63 and can't be returned as they are special order from Aircraft Spruce in the US. You now have all the info, but contact me if you need more. £35 would do the trick.
