Mon Jun 09, 2014 4:21 pm
#1288807
Higher res photos here and here
Removed for various panel upgrades - Permit only
52mm Manifold pressure + 4/5mm hose connector SOLD
52mm Fuel pressure 10psi + 4/5mm hose connector -£50
80mm Electronic Tacho for Rotax 912/914 - hour meter shows 96hrs - £100
Other (suitable for Rotax senders or VDO) 52mm 12V lighted - £25 each
Water Temp 0-150C (Rotax CHT)
Oil Temp 0-150C
Oil Pressure 1-10 bar SOLD
2 x Fuel Gauges (resistive)
Voltmeter 12V
Ammeter +/- 30A direct connection (no shunt) SOLD
Above are 50% new prices http://www.star-company.net
3-1/8" Stewart Warner Tachometer (820586) showing 187 hrs inc 32" Lycoming cable - £50
2-1/4" Oil Temp gauge with sender - £40
3-1/8" VSI (2000fpm) Falcon (2FM-3) with screw clips - £50
Located Glos
