Day 12 was to be the last day that we would fly together in groups. Plan was to fly the coast from Anchorage to Yakutat, refuel and lunch then to continue the coastal route to Ketchican - the southernmost large airport in Alaska. But the weather dictated otherwise with a large area of rain and cloud extending down the coast for about 100 miles. The freezing level was also below MEA ruling out that route for both VFR and IFR.
An alternative plan looked tempting; through the Tahneta pass to Gulkana and then down the Copper River which gave better options for crossing to the coast. Fortunately Alaska is awash with webcams at airports and critical locations. A check of those showed this to be a good option together with TAFs and Metars along the way.
A few delays meant we left behind the main group and three of the crews decided to chance waiting for better weather, while the two Cirri opted to go IFR and put their faith in the TKS.
This proved a good plan with only a little scud leaving Merrill field to the NE and excellent VFR and generally smooth air up the Pass to the Copper River Valley.
Down the valley, the Tana glacier spills off the Bagley icefield and opens into a side valley. This looked a good opportunity to cross to the coast finding our way through some scattered cloud layers and emerging over Yakatagas turf runway and a clear way forward down the coast.
The coast down here is quite spectacular as evidenced by the cruise ships at regular intervals. Glaciers spill directly into the ocean 15-20,000' high peaks line the coastal range, bears are scavenging along the beaches and whales can be seen frequently. The aptly named Icy Bay spills icebergs from the Yahtse glacier.
We joined the main group at Yakutat and filled up with the most expensive gas so far, other than Canada, at $7.60/usg.
The next leg to Ketchican started off mostly flying the coast at 500', getting a better view of the wildlife, just climbing to cross the islands into the Clarence Strait and dodge a few local cloud-bursts. This was proving a superb conclusion of our group tour.
Ketchican hurried our flight in ahead of an inbound 737 and we all touched down in about 3 minutes from lead to tail, while floatplanes were splashing down on the adjacent harbour simultaneously.
The airport is on a separate island to Ketchikan city so a short ferry ride takes us to our final Alaskan destination.
Next day was a rest day with a crab feast organised for the evening. Ketchican is famous as the wettest mainland city in the USA (ignoring Hawaii) and this proved itself with a 500-1000' overcast setting in with intermittent rain.
From Ketchican it's only 600NM to the Seattle area, so a flight can be made back to the lower 48 without international formalities of customs, EAPIS, CANPASS etc.. Freezing levels were up at 13000' this time, so we all filed IFR and took off into the 500' ceiling, breaking into the sunshine at 8000', just below my filed 9000' cruising level.
Breaking into clear weather after an hour down route, we had a fine run back to Olympia for a final parting from those others who came back to our start point.
Still only 2 pm we decided to push on back to L.A. with CAVOK all the way. Crater Lake greeted us with clear calm water for a final photo opportunity.
A refuel in Norcal and into darkness watching a distant intense thunderstorm over the Sierras and into the basin where a marine layer was still holding off far enough to safely return to Hawthorne.
6000 miles, 37 hrs flying, wallet depleted and one fantastic trip completed. Highly recommended.
