Saturday 25 May 2013 04:28 UTC |
Latest FLYER headlines:
Using MS Word as it should never be used. Expert needed.I have a client for whom we designed a letterhead that bleeds on all four edges.
Client now wants a Word Template on which they can type, but one that if they 'print' as a PDF also bleeds, and has no white borders. Is this achievable? Rob P Forum Diversity & Equality Officer (unpaid)
"We sleep soundly in our beds because rough men stand ready in the night to visit violence on those who would do us harm." - George Orwell-
So are you wanting word to print differently, depending on whether its to a PDF or to a printer?
Word doesn't know the difference between printing to PDF and to a printer, so that would be difficult. Presuming that you only want to create a single template, which will only be used for printing to PDF, I don't think that should be a problem. However, I may well have just misunderstood your issue! How are your MS Word skills? I don't want to patronise! (I'm using Word 2010). I presume that your letterhead is a high-quality image, but most of the same would apply to text - just put the text in a text box. Double click on the header section of the document. Insert the image into the document inside the header section. This is important as it wont then interfere with what someone is typing in the main part of the document. Right click on the image, select wrap text / Behind text. Position the image as you wish, with the bleeding parts off the side of the visual document. ie: Drag the image so that the top and left edges disappear off the side of the "paper" showing the level of bleeding that you want on the left side and top. Expand the image to the lower right, off the side of the document, again to show the amount of bleeding that you want. Select the picture and go to the picture tools / format ribbon. Select Crop. Crop the bottom of the image to the amount of bleeding you want to remove. If you want different things on different pages, select the appropriate options in the header menu (header & footer tools ribbon / Design / Different First Page) Save as a template (File / Save as / Save as type: Word Template (dotx) ). You could of course, select an appropriate font and all the rest for them too... As far as Print to PDF is concerned - the printer driver that the pdf generators provide (at least - certainly the one on my laptop which was freeware) tell MSWord that they can "print" to the edge of the page, so there would be no blank space at the sides, and MSWord wont complain. If you try to print to a normal printer, then MSWord will warn you that the margins will mean that somethings may get cut off. To use the template, when the user is creating a new document, they need to select your template rather than a blank document. If you PM me your email address, I could send you a template I've just been messing about with you show you what I mean.
Re: Using MS Word as it should never be used. Expert needed....and if you're printing the "oversize" (i.e. bled) PDF make sure that the print option "Page scaling" is not set to "Shrink to printable area".
“I am somehow less interested in the weight and convolutions of Einstein’s brain than in the near certainty that people of equal talent have lived and died in cotton fields and sweatshops.” Stephen Jay Gould
Wow! Many thanks.
I am really not ready to tackle this at gone midnight, I'll take a look tomorrow and see if it's sorted. I'd have no problems myself with a multi-stage process, the trick will be making it simple enough for the client to use easily. Rob P Forum Diversity & Equality Officer (unpaid)
Small delay over weekend, but now up to my oxters in it again
So far a big fail Here's what I have done so far 1) Taken the 'artwork' pdf of the letterhead and converted it to a jpg using PhotoShop CS3 2) Cropped it at the bleed marks using the dimensions 30.1 x 21.5cm for the cropping tool 3) Pasted this into the Word header, setting text options to 'Behind Text'. The Word document size is set to custom 30.1 x 21.5 cm 4) Saved the resulting as an MS Word template So far so good. I now have a template that if Word on 'printing' decides to crop slightly, then it will look perfect 5) Select 'Cute PDF' as the printer 6) Check that 'paper' size is set to A4 7 Push the print button. Fail! Any further thoughts? Rob P Last edited by Rob P on Mon Jan 07, 2013 4:48 pm, edited 1 time in total.
You answered your own question really
This was allowing for Word's propensity to suggest that there is "matter outside the printable area" and then cropping So I only cropped down to the bleed marks, not the trim - See 2) Rob P Forum Diversity & Equality Officer (unpaid)
Who is onlineUsers browsing this forum: Dave Phillips and 4 guests |
FLYER Exhibitions
Login / Register
