Friday 24 May 2013 23:33 UTC
Latest FLYER headlines:
More news
Towing Socket Electrics
This is the place for anything not connected with aviation. Strict rules of engagement apply. The moderators' decision is final.
Bill McCarthy
Lost Cause
Postby Bill McCarthy » Mon Dec 31, 2012 3:13 pm
No matter how careful I am to ensure no moisture ingress into my 7-point towing socket, it gets in there somehow. The latest problem is the ABS light coming up on the dashboard if I brake and indicate "right" at the same time. Although the alarm indicates (stays on until reset by the ignition key), this does not affect braking duty other than to remove the automatic facility. Clearly, there is a "short" in the socket housing or at the point where the leads are routed from the main wiring loom to the rear lights. Have any readers pumped in some insulating gunk that fills the socket void, thereby keeping water out. This defect, on my Toyota Hi-Lux.
Antagonise no man, for you never know the hour when you may have need of him.
BobM
Forumite
Postby BobM » Mon Dec 31, 2012 4:23 pm
I've just put a new socket on the Trooper and made sure all connections were covered in Vaseline before refitting, hopefully it will avoid similar problems.I regularly clean the terminals with Scotch Brite and spray WD 30. Seems to work so far.
Experience is something you don't get until just after you need it.
Keef
Just Keef
Postby Keef » Mon Dec 31, 2012 4:24 pm
Sounds like a dicky earth connection to me. Check it's all clean, and then use liberal quantities of WD40.
Keef
Moderatio in omnibus
Ridders
Pup Flyer
Postby Ridders » Mon Dec 31, 2012 4:45 pm
Ive got one of those push on PVC covers over the socket that goes over the entire socket.
One like this
Our Deanland ALG fly-in is 8th June 2013 Fly-Ins and Social Events for more info
Flintstone
Sad Forumite
Postby Flintstone » Mon Dec 31, 2012 5:47 pm
BobM wrote:WD 30
Cheapskate.
mancpilot
Senior Forumite
Postby mancpilot » Mon Dec 31, 2012 6:47 pm
Bill McCarthy wrote:No matter how careful I am to ensure no moisture ingress into my 7-point towing socket, it gets in there somehow. The latest problem is the ABS light coming up on the dashboard if I brake and indicate "right" at the same time. Although the alarm indicates (stays on until reset by the ignition key), this does not affect braking duty other than to remove the automatic facility.
I'm baffled as to why any kind of short at the towing electrics would have any effect on the ABS circuitry, since the towing electrics shouldn't have any ABS circuitry in them...
The patient was in his usual state of good health until his airplane ran out of gas and crashed.
Bill McCarthy
Lost Cause
Re: Towing Socket Electrics
Postby Bill McCarthy » Mon Dec 31, 2012 6:51 pm
mancpilot - there must be some interference in there somewhere - it's the same when I have the headlights on indicate either left or right.
BobM
Forumite
Postby BobM » Mon Dec 31, 2012 9:21 pm
Couldn't afford 40, that's for big boys!!
Keef
Just Keef
Postby Keef » Mon Dec 31, 2012 9:55 pm
Dicky earth connection.
They have some fascinating effects as they connect together different bits of the car's electrics that weren't expecting to be connected. "No earth" means that positive volts from the brake lights feed through to the flashers, or the sidelights, or wherever, and vice-versa. The easy check is to see if the brake lights, flashers, etc work correctly on the trailer.
Keef
pb6797
Sad Forumite
Postby pb6797 » Mon Dec 31, 2012 10:00 pm
Do you have an OBD-II logger unit (or can borrow one)? I'd like to see what the reported error actually is.
I'm a bit concerned that there is something bridging your earth and live or similar, headlights and indicators affecting brake lights sounds like a French car, not Japanese one ...
Colin G
Aviation Junkie
Postby Colin G » Tue Jan 01, 2013 5:24 pm
ACF50 works a treat. A good spray every 12 months.
"You can make things happen, watch things happen or wonder what the **** happened"
bibendum
Sad Forumite
Location: Pilot's Retreat, London Moscow Sherburn in Elmet International Airport
Postby bibendum » Tue Jan 01, 2013 6:19 pm
You didn't say whether this was happening with or without a trailer connected? If only with the trailer then the problem might be that rather then the car.
I'd be surprised if it was just "damp" that was causing your problem. We came back from the Yorks Dales yesterday towing the caravan through floods over 12" deep (that would have completely submerged the towing electrics on the Discovery) with no ill effects.
Duff earth seems the most likely cause, and this might be provoked by corrosion somewhere (the result of damp) rather than just being damp.
If you really suspect the 7N socket (or trailer plug) replace it and see what happens. I tend to do this every 3 years or so anyway as the design is pretty rubbish.
The current 13 pin sockets are a better design that use stainless steel for the pins. That might be a longer term solution if corrosion in the plug/socket is the problem.
Bill McCarthy
Lost Cause
Postby Bill McCarthy » Tue Jan 01, 2013 6:21 pm
Once the frost clears (as well as my head after last night) I'm going to start with the towing socket loom wiring connections. There was a problem (fixed under warranty some years ago) when I applied brakes, the headlamps came on. It could be that they had just wrapped the joins in insulating tape.
bibendum
Sad Forumite
Postby bibendum » Tue Jan 01, 2013 6:22 pm
Ridders wrote:Ive got one of those push on PVC covers over the socket that goes over the entire socket.
One like this
They look pretty, but the water gets in from the dodgy seals at the back and then can't get out again because of the cover.
pb6797
Sad Forumite
Postby pb6797 » Tue Jan 01, 2013 11:35 pm
Bill McCarthy wrote: There was a problem (fixed under warranty some years ago) when I applied brakes, the headlamps came on. It could be that they had just wrapped the joins in insulating tape.
Without the trailer? Yikes.
Return to Non aviation stuff
Who is online
Users browsing this forum: mancpilot and 6 guests
click here Login / Register
