Wednesday 19 June 2013 09:12 UTC
Latest FLYER headlines:
Schneider Trophy Air Race celebrates 100 years  -  HIAL passenger numbers up by 8,000  -  First production version of Great Lakes biplane
More news
Cockpit video of A380 landing at SFO
This is the place for anything not connected with aviation. Strict rules of engagement apply. The moderators' decision is final.
PaulB
Beyond Hope
Postby PaulB » Fri Dec 28, 2012 7:26 pm
This has probably been posted before so I apologise in advance, but I've only just seen it.....
Paul
PaulB
Beyond Hope
Postby PaulB » Fri Dec 28, 2012 9:39 pm
In the video, the A380 is cleared to land on 28R. Shortly after an aircraft is cleared to take off on 01R. You can see it on its take off roll pass infront of the A380. Would that happen in the UK?
Paul
Flintstone
Sad Forumite
Postby Flintstone » Fri Dec 28, 2012 10:15 pm
Land And Hold Short Operations (LAHSO)? I've not watched the video. http://www.aopa.org/asf/publications/lahso.html
Not much call for it round these parts.
BobM
Forumite
Postby BobM » Fri Dec 28, 2012 10:58 pm
I think all UK operators are banned from LAHSO ops in the USA,
CAP 789
19.2 The CAA does not approve UK operators to participate in LAHSO. The CAA is not
aware of any non-US operators who have met the FAA requirements for a Part 129
approval to participate in LAHSO. Therefore, if such a clearance is offered the crew
should decline unless, in the best judgement of the commander, safety would be
jeopardised. Furthermore, crews should be aware that the white strobe lights used
to indicate the hold short point would remain on even if a particular aircraft is not
required to hold short. The comments section of all ATC Flight Plans should include
the comment that the aeroplane is not able to accept a LAHSO clearance and crews
should inform the US ATC that they are "unable to accept LAHSO" on first contact with
relevant frequencies.
Experience is something you don't get until just after you need it.
PaulB
Beyond Hope
Postby PaulB » Fri Dec 28, 2012 11:52 pm
But is what's on the video LAHSO? The A380 was on final for 28R and cleared to land, then another aircraft was cleared to take off on 01R and crossed 28R in front of the 380 while it was still on final.
Would that situation occur in the UK? Picking (say) Gloucester as an example (merely because it has multiple runways and has full ATC) would they clear someone to take off on 36 while someone else was on final for 28 (or is it 27 - not been for a while... sorry, MatsPt3) and cleared to land?
Paul
Skymonster
Forumite
Postby Skymonster » Wed Jan 02, 2013 12:06 pm
That's not a land and hold short... Happens all the time at San Francisco is cleared to land in the 28s and then there's a subsequent clear to take off on the crossing 01s the "assumption" being the departing traffic will have cleared the intersection before the landing traffic rolls out... Remember that in the USA you can also get a clear to land whilst still number two or three on approach...
Andy
There are old pilots and there are bold pilots, but there are no old bold pilots
Flintstone
Sad Forumite
Postby Flintstone » Wed Jan 02, 2013 1:29 pm
Well I did say I hadn't watched the video (all that teutonic correctness, gives me the heebies) and quantify the LAHSO suggestion with a '?'.
LAHSO had a trial run in Darwin when I was there sometime in the mid-90's. It was alright to be cleared to land and hold short in (say) a Cessna 402 but I'd be less inclined in something larger. I think they decided to drop it.
Edit: Just ran some of the video, the landing phase, to listen to the radalt callouts and the male voice reminded me of something that came up in a CRM class a few years ago. It seems that the manufacturers of military aircraft thought it might be a good idea to use a female voice to call out cautions, warnings, fires and the like. Which worked fine on fighter pilots who were family men. Others, perhaps more testosterone fuelled, tended to ignore the voice.
Boing_737
Senior Forumite
Re: Cockpit video of A380 landing at SFO
Postby Boing_737 » Wed Jan 02, 2013 2:16 pm
Also, who knew Magnum PI was an actual person....
malcolmfrost
Forumite
Postby malcolmfrost » Wed Jan 02, 2013 2:50 pm
+1
There are also two types of LAHSO, passive and active. passive is where another aircraft is told to land and hold short of your runway, active is where you are told to land and hold short of another runway.
UK aircraft aren't allowed to do either. The passive one is sometimes difficult to spot!
JoeC
Lost Cause
Postby JoeC » Wed Jan 02, 2013 3:06 pm
Flintstone wrote:Others, perhaps more testosterone fuelled, tended to ignore the voice.
"retard, retard"
Return to Non aviation stuff
Who is online
Users browsing this forum: anglianav8r, Google [Bot], nbayliff and 7 guests
click here Login / Register
