Tuesday 18 June 2013 07:18 UTC |
Latest FLYER headlines:
bean to cup coffee machineMy Delonghi machine has ust gone kaput, so may be looking for a new one.
I had a Delonghi Magnifica which we paid £200 or so for about 3 years ago. I can look online and the same machine seems to go for between £240 and £380 - seems a huge difference in price. Anyway, could be in the market for a new one (will see whether current one is worth fixing) but thought I would ask the experts what they would recommend. Don't want to spend a fortune and really want something that is easy to use (hence bean to cup) - won't rule out grinding my own beans but would prefer an integrated solution. Not interested in nespresso etc. I sometimes don't do smilies
I think you got a good deal at £200 for a bean-to-cup machine.
We have a ESAM04.350.S here in the office - but that's a much more expensive machine (a so called 'superautomatic' that can deliver a complete cappuccino with one button). It has worked really well for us and so far has delivered over 1000 drinks without a problem. £500+ though At home, I have the mother of all coffee machines - a Jura Impressa Z5 II, which even second hand cost me the price of a decent used car... Is it that much better than the Delonghi? Well, no, not really, but it looks a lot prettier An alternative to buying a new Delonghi would be maybe to look at a used Saeco or similar. There are loads of bean-to-cup machines on eBay and there is an occasional bargain to be had. PHENOMENOUS DANGEROUSNESS
Re: bean to cup coffee machineI can recommend Saeco, had one for almost 6 years, never any problems. If you go this route make sure you get one with real buttons rather than a touch sensitive pad as these tend to fail after 3-4 years.
I remember when sex was safe and flying was dangerous.
Software engineer, pilot and expatriate
Sorry, must do it the traditional way. Burr grind the beans, then into the Bodum Stovetop, onto the Jetboil!
Had a couple of machines, but the last one (a mid price DL) ended up in the loft after a back to back taste test. The nice bit about my setup is that I can sling it into the back of the car, or a rucksack, or even hang it off a belay halfway up a mountain
Gaggia Classic is the way to go.
I think mine is over 10 years old now and going strong, did get it recently serviced. According to some of the coffee forums (fora) e.g. http://www.toomuchcoffee.com separate grinding is essential and almost as important as the coffee maker. It might be unlikely that a bean to cup machine will do a good job. PS there's some stuff for sale on there too.
+1 - I still have 2 of these, one now with my son in his Uni house At about £200-250 the Gaggia Classic is the best coffee maker < £1000. Used properly, it will blow the B2C coffee out of the water. It doesn't need superman skills, just a few pointers:
FG
But then you always get the annally retentive on any forum who claim the purists route is the only route. Had my Delonghi for over three years and it made excellent coffee, much better (and cheaper) than the nespresso that it replaced. Dont really want to grind separtely as I am a messy git and the combined approach keeps Mrs S771 happy. I sometimes don't do smilies
Whats too complicated about topping up beans and water once every few days/once a week (depending on use) and then pressing a button to get an espresso? The whole idea of these machines is that it is not complicated. The delonghi even has a "clean cycle" that it goes through when switched on/off. Much more versatile than nespresso/senseo machines in that you can easily change the strength of your drink - i.e. more or less water and more or less ground coffee. Mrs S771 wouldnt use the nespresso as even the weak coffees were too strong for her. I sometimes don't do smilies
Ok, I'm going to "come out" here, and say that I bought one of these a few weeks ago:
http://www.gaggia.com/macchine-da-caffe.asp?macchine-per-espresso-automatiche_117_Platinum-Vision ![]() They've not got brilliant reviews on the internet - or rather they vary - everyone says "excellent coffee", but many also say "unreliable". It's Italian. One reviewer said think Alfa Romeo compared to the Siemens Mercedes Benz. Anyway, what prompted me to get this was a special offer on e-bay! Comet had an offer on where the bottom of the range Gaggia bean-to-cup machine was reduced from £350 to £250, so I thought of getting that. It has the same ceramic burr grinder as the more expensive ones. However, the Platinum Vision had more settings and adjustments, but normally costs £700. $1300-$1400 in the US! I suspect I'm asking for trouble getting a computerised touch screen Italian machine, but for the moment it seems to work very nicely. There's only one problem I have and that's that now I seem to be getting through coffee beans like there's no tomorrow, as it's just so easy to press a button and get coffee. The ceramic burr grinder is apparently not to burn the beans as it grinds like a steel one. It has three settings, but the fine setting seems ok. I haven't tried the others. You can change the settings for amount of coffee used, and time taken for both pre-brew and brew. You have three cup sizes at the touch of a button but each of these can be adjusted to the size you want. It's just as easy to get a long coffee as an espresso. You can also adjust the temperature of the brew, though this seems to be three settings. I have it on the hottest and strongest for everything, but I think that's just me! It's on wheels of sorts which allow you to rotate the machine each way to fill up the water and empty the coffee grinds. It has automatic cleaning settings (and rinses itself on power up if you switch it off completely) and even a setting for adding descaler, though the water bucket thing has a (replaceable) water filter in it so hoping I won't need to do that very often! I guess we could start talking now about tips and stuff. I've ordered some coffee beans on-line for the first time, so I'm looking forward to experimenting with different types of bean. Last edited by Paul_Sengupta on Thu Oct 11, 2012 1:07 pm, edited 1 time in total.
Re: bean to cup coffee machineKitchen aid burr grinder, kitchen aid coffee maker. Not cheap and not small but they look the part and the coffee is good.
CPL IMC FI (A) and registering 9 on the bolometer.
Don't know, do you think I should try it? I've ordered some Lavazza Crema e Aroma beans and some Indian beans. Though the Waitrose beans I've used so far, I've noticed that the darker roast makes a better espresso while the lighter roast makes a better long coffee. Hoping to find a bean and roast which makes both! Who is onlineUsers browsing this forum: Bing [Bot], Majestic-12 [Bot], mr tambourine man and 4 guests |
FLYER Exhibitions
Login / Register
