Friday 24 May 2013 20:05 UTC
Latest FLYER headlines:
More news
Raspberry Pi
This is the place for anything not connected with aviation. Strict rules of engagement apply. The moderators' decision is final.
JoeC
Lost Cause
Postby JoeC » Thu Mar 29, 2012 2:20 pm
http://www.bbc.co.uk/news/technology-17547764
British ingenuity and manufacturing at it's best!
JamesB
Forumite
Postby JamesB » Thu Mar 29, 2012 2:36 pm
They're manufactured in China. The original plan was to do it in the UK, but apparently price considerations came into play.
JoeC
Lost Cause
Postby JoeC » Thu Mar 29, 2012 2:47 pm
Sorry, should have said British manufacturing management....
bar shaker
Needs Help
Postby bar shaker » Thu Mar 29, 2012 3:21 pm
JoeC wrote:Sorry, should have said British manufacturing management....
Joe, we would have to know if the spec was at fault or if the manufacturer used the wrong part, before piling blame onto the designers... let alone burying them just because they are British.
If I come across as proud of our engineering and innovation companies it is, er, because I am.
JoeC
Lost Cause
Postby JoeC » Thu Mar 29, 2012 3:30 pm
I am equally as proud of the British traits of humour and self-deprecation. And blaming foreigners when things go wrong. I like that one too.
JamesB
Forumite
Postby JamesB » Thu Mar 29, 2012 3:39 pm
You can read Raspberry Pi's blog on the incident here and make up your own mind as to whom to blame :) ... http://www.raspberrypi.org/archives/781
Peter Pan
Finally grown up!
Postby Peter Pan » Sat Mar 31, 2012 5:51 pm
Just got an email 16.01 saying I could order. Placed an order and got the email
When stock is allocated to your order, we will send you a full order confirmation including prices, availability and expected delivery date.
Can't wait! £29.26 :D
Colonel Panic
Back on duty!
Re: Raspberry Pi
Postby Colonel Panic » Sat Apr 28, 2012 10:38 am
In anticipation of a w/c 28-MAY shipping date I'm starting to think about peripherals. I will use an old USB keyboard and mouse initially (may upgrade to bluetooth & a USB bluetooth dongle later?), and an el-cheapo headset (3.5mm jack) for sound.
I'm very keen to keep costs down to a minimum on this project; the monitor that I would like to use only has a 15 pin VGA input; what would be the best way to get the Pi's video out in to my monitor? Is there such a thing as an HDMI to VGA converter? Or should I look for a Composite video to VGA lead?
Any ideas for which route would be OK quality-wise but cheap too? (AIUI the monitor has a max resolution of 1024x768@75Hz)
Would this do?
http://www.amazon.co.uk/S-VIDEO-ADAPTER ... pd_cp_ce_0
Ian Melville
Needs Help
Postby Ian Melville » Sat Apr 28, 2012 11:27 am
From the Raspberry Pi FAQ
What display can I use?
There is composite and HDMI out on the board, so you can hook it up to an old analogue TV, to a digital TV or to a DVI monitor (using a cheap adapter for the DVI). There is no VGA support, but adaptors are available, although these are relatively expensive.
Since that adaptor is the wrong way round it won't work.
A quick search found a HDMI output to VGA input adaptor at £40, so I guess they are expensive as mentioned in the FAQ. Cheaper to buy a second hand DVI monitor and HDMI - DVI adaptor
Colonel Panic
Back on duty!
Re: Raspberry Pi
Postby Colonel Panic » Sat Apr 28, 2012 1:11 pm
Ian - thanks for that. Very helpful. If I can possibly avoid spending £££ on a new (or old) monitor so much the better. I've dug out an old TV which has ...
    Scart
    S video
    Video input phono jack (yellow) and x2 audio (white and red)
Would this enable me to use a cheaper lead? Can I not connect the Pi's Composite video out port to the TV's S video in or the video input phono jack? I'm sure that I'll have a yellow RCA to yellow RCA video cable (from an old video camera) lying around somewhere.
Apols in advance for being a bit of a numpty :oops:
Keef
Just Keef
Postby Keef » Sat Apr 28, 2012 1:26 pm
I'm going to wait till mine arrives to tinker with the plethora of leads, monitors, TV sets, etc in the workshop to find what will display. I'm sure something will fit!
Meanwhile, I went on the hunt for software. Two downloaded almost instantaneously - archlinuxarm-27-03-2012.zip and debian6-13-04-2012.zip
and while I was at it, I grabbed Raspberry-Pi-Schematics-R1.0.pdf
I don't know if I need RaspberryPi-Development-VM-v0.8.ova but it looked interesting so I decided to. It's 8.2GB and has been 14 hours downloading so far (albeit very slowly, so I suspect lots of people are doing the same). It reckons another 7 hours to go.
If anyone wants it and doesn't want to download it, send me a 16GB memory stick and I'll do the necessary.
Keef
Moderatio in omnibus
Colonel Panic
Back on duty!
Re: Raspberry Pi
Postby Colonel Panic » Sat Apr 28, 2012 2:08 pm
What does the .ova do? Allow you to run a Pi OS in a virtual machine?
Keef
Just Keef
Postby Keef » Sat Apr 28, 2012 2:16 pm
It's a tool to create a virtual machine for developing software for the Pi. It also allows data transfer between the Pi and the virtual machine.
The details I saw were a bit vague, but it seemed like something needed to do serious stuff with the Pi. I found the reference to it here.
There's also an expansion board for the Pi - called Gertboard. I'm going to hold off on that till I've got used to the basic device.
Keef
Colonel Panic
Back on duty!
Re:
Postby Colonel Panic » Sat Apr 28, 2012 3:30 pm
Keef wrote:Meanwhile, I went on the hunt for software. Two downloaded almost instantaneously - archlinuxarm-27-03-2012.zip and debian6-13-04-2012.zip and while I was at it, I grabbed Raspberry-Pi-Schematics-R1.0.pdf. I don't know if I need RaspberryPi-Development-VM-v0.8.ova but it looked interesting so I decided to.
I've downloaded the debian6-19-04-2012.zip, but no doubt it will be superseded by the time my Pi arrives; the schematic is waaaaay above my head, and I'll pass on the .ova for now.
Should we set up a competition for the first person to be able to successfully code
    10 PRINT Hello
    10 GOTO 10
:D
EDITED TO ADD ... I even managed to run a successful SHA-1 Checksum test on the download. Ooh err, I've done one of them before 8)
Jodelman
Forumite
Postby Jodelman » Sat Apr 28, 2012 4:47 pm
Colonel Panic wrote:I've dug out an old TV which has ...
    Scart
    S video
The yellow one will be ok. Lots of useful tips on this forum.
PreviousNext
Return to Non aviation stuff
Who is online
Users browsing this forum: ATCO Jim, Gary H, grindlay and 12 guests
click here Login / Register
