I've just finished eating a delicious ham roll. I made the French dough in the breadmaker and did a bit of off piste kneading and proving to make the rolls then baked them in the oven. Made 4, rest will be consumed tonight.
[quote='harry remmington']Convinced BUT what is the difference between Panasonic SD255 [Amazon £86.31 inc. delivery] and SD255WXC ? - more expensive but seems to have the same spec. ?[/quote]
Knickers:
Didn't think of Amazon- mind you a bent Amazon employee was(allegedly) responsible for my CC cloning last year and I haven't used 'em since.
Couldn't wait for delivery: Argos it was: a tenner more than Amazon, Cheaper than Currys or Comet, same as J Lewis. Mine's got wxc on the box too.
Can't smell the bread cooking yet: have resisted the temptation to take a peek.
Steve, how do you go about getting a second rising of the dough? (This is not a masonic question - those who are will understand, those who aren't ....won't).
[quote='Lindsayp']Steve, how do you go about getting a second rising of the dough? (This is not a masonic question - those who are will understand, those who aren't ....won't).[/quote]
Set one of the ovens to 40 deg. If you have an airing cupboard it will do. Room temperature is too cool.
Yup. When I made bread before the tricky bit was mixing and kneading. Now all that is done and all I have to do is final kneading, shaping and proving.
I dont think i'll do my own croissants though. Too much like hard work!
The second kneading can be more of a 'knocking back' (technical term) than full kneading, unless you need to relieve some tension or clean your finger nails.
Tall_Guy_In_a_PA28 wrote:The second kneading can be more of a 'knocking back' (technical term) than full kneading, unless you need to relieve some tension or clean your finger nails.
Just got the 255 but instructions are a bit vague.
What happens if you only want a small loaf using 250grm of mix.
Does the machine adjust its baking time or is it the same cycle for any weight or size ?
Avatar - "When a HUET goes wrong"
Sent from my personal transponder on the International Space Station and sponsored by Pukka Pies
I just do a 250 grammes loaf and I just register it as a small loaf but with a light crust. It works well, the only problem with a smaller loaf is that the paddle seems to stick in it a bit more
Dream as if you'll live forever, Live as if you'll die today.
