Monday 20 May 2013 00:17 UTC
Latest FLYER headlines:
More news
Goals once qualified.....
If you're learning to fly, or thinking of learning, then here's the place to post your questions, comments and experiences
Lottie
Junior Forumite
Re: Goals once qualified.....
Postby Lottie » Thu Jan 03, 2013 3:07 pm
Interestingly many of the comments above echo what I've been told about concentrating on one type and consolidating what I've learnt. Ultimately for me flying is something I do for fun so there's no rush.
I passed my skills test in Feb (last year now!) and spent a few hours solo flying simple routes and then did a few passenger flights. I took "advantage" of the olympic airspace and had a lesson then (as the club was within the zone) as well as my own flight. I was also never very happy with my forced landings (I seem to have a mental block where I get stuck trying to spot the perfect field!) so I had a further couple of hours practising them and trying out different techniques - I have changed what I do slightly and now feel much happier.
I too had wanted to do the tailwheel conversion but couldnt and then decided to upgrade from a 152 to a 172. Having been checked out in the 172 I am now doing the "advanced" PPL - which is cool because I spend time with my instructor doing things I'd like to practice and then also the extended "syllabus" - we've done a landaway at the club's "standard" alternate and so far flights practicing gliding and simulating problems with the aircraft (loss of instruments, jammed controls etc). All of which I've really enjoyed. Next up is some more instrument flying I think and also some more landaways
The IMC is next (before the deadline) and for the time being I've decided to focus on getting to know just one plane well - though I too had spotted the cambridge aero tailwheel lessons!
Paul_Sengupta
Season Ticket Holder
Postby Paul_Sengupta » Thu Jan 03, 2013 4:18 pm
Lottie wrote:The IMC is next (before the deadline)
What deadline?
Genghis the Engineer
Forumite
Postby Genghis the Engineer » Thu Jan 03, 2013 4:48 pm
All of which you can do on your own, without paying for an instructor, and without their becoming a crutch to stop you developing your own command experience. There is of-course, no such thing as an advanced PPL either.
(That said, there's no reason not to do this sort of flying with an instructor to develop your skills, but it shouldn't be the majority of your flying, in my opinion.)
riverrock
Forumite
Postby riverrock » Thu Jan 03, 2013 5:09 pm
What deadline?
You can only add an IMC rating (AKA IR(r) ) to a Part FCL licence up till 8th April 2014 according to http://www.caa.co.uk/docs/2330/Revised% ... %20_v3.pdf
After that you would get an IMC Rating on a separate national licence which would only be valid for Annex II Aircraft, or alternatively you could get an Enroute IR on your Part-FCL licence, which would allow you to use airways but not to take off / land / use instrument approaches (ie its the other half of the IR from the IMC Rating - all the things that an IMC rating doesn't allow you to do).
Hopefully things will change before then - but I believe that's how it currently stands.
Lottie
Junior Forumite
Postby Lottie » Thu Jan 03, 2013 6:48 pm
Genghis the Engineer wrote:All of which you can do on your own
True.
Genghis the Engineer wrote: without paying for an instructor
Again true. I suspect though that I may not have tried as much new stuff given my low hours. In the scheme of things an instructor is not much more expensive.
Genghis the Engineer wrote: and without their becoming a crutch to stop you developing your own command experience
Interesting point, hadn't thought of it that way.
Genghis the Engineer wrote:There is of-course, no such thing as an advanced PPL either.
Indeed hence the quotes.
Iolanthe
Forumite
Postby Iolanthe » Fri Jan 04, 2013 4:16 pm
With reference to the Chippy debate (sounds like something in the House of Commons!) I'll let you know when/if it happens. I am sure that side of the discussion will then go on :wink: (and probably start a new thread!)
With reference to paying of instructors to help out once qualified...the ideal solution is to make friends with your FI so then annual club checks and "extra" tuition will be part of a flight where there are two pilot friends just up enjoying the thrill of flying! :)
Iolanthe "The Flying Curator"
PPL Student
Home Airfield: EGYD
Exams Passed: Met; Air Law; Comms
Floobie
Junior Forumite
Postby Floobie » Mon Jan 07, 2013 3:05 pm
Things I'd like to do in no particular order:
Lunch in Le Touquet
Night Qualification (Or Rating or whatever!!)
Instrument Rating
Fly to the Private Strip a quarter of a mile from the back of my Mum's House in Suffolk
Take flying the growing list of friends I have promised to take flying with me when I pass.
Build up some hours flying in America (probably Arizona) - start working towards CPL
Fly my Dad down to his place in the Algarve from UK(ambitious this one I know!)
Join in some fly ins.
Probably get familiar flying the PA28 as have just been in the Cessna 152
All of this of course if the bank allows it!
Keef
Just Keef
Postby Keef » Mon Jan 07, 2013 4:02 pm
Where's mum's house in Suffolk?
Keef
Moderatio in omnibus
riverrock
Forumite
Postby riverrock » Mon Jan 07, 2013 4:40 pm
Iolanthe wrote:With reference to the Chippy debate (sounds like something in the House of Commons!) I'll let you know when/if it happens. I am sure that side of the discussion will then go on :wink: (and probably start a new thread!)
Or marry his daughter...
Um - on second thoughts - thats probably been the much more expensive option :pirat:
White Vans Man
Location: Tibenham - aka London Jimmy Stewart Executive Airport
Postby Rob P » Mon Jan 07, 2013 4:44 pm
And for Iolanthe it would have to be a civil partnership anyway :oops:
Floobie
Junior Forumite
Postby Floobie » Mon Jan 07, 2013 5:29 pm
Keef wrote:Where's mum's house in Suffolk?
Newman's Green near Acton and Sudbury. A farmer has a grass strip there where he lands his Cessna 172. Had a look at it over Christmas and decided it was definitely doable (with a bit more practice).
Keef
Just Keef
Postby Keef » Mon Jan 07, 2013 5:53 pm
That looks a nice strip, but it's fairly short for a C172/PA28. A perfect taildragger place!
Keef
Iolanthe
Forumite
Postby Iolanthe » Mon Jan 07, 2013 7:45 pm
As far as that side of life goes Rob, you may rest assured that I am quite normal!!!!!!! :wink:
Well chaps, i'm going to be in purdah for a couple of days now as I have Comms written on Thursday.....
..then i'll be thinking about the RT practical :pale: Talking to our CFI today, he suggested when ready, FI and I fly a landaway to Sibsons, as the guy there is quite nice apparently...or theres Leicester or Nottingham City... Any preferences any one? I so far have one vote for Sibsons....
I
PPL Student
Home Airfield: EGYD
White Vans Man
Postby Rob P » Mon Jan 07, 2013 8:41 pm
Sibson is good. (It's singular)
Forum Diversity & Equality Officer (unpaid)
"We sleep soundly in our beds because rough men stand ready
in the night to visit violence on those who would do us harm."
- George Orwell-
pb6797
Sad Forumite
Postby pb6797 » Mon Jan 07, 2013 11:31 pm
Sibson is quite short with power lines on the approach and is A/G only - maybe not ideal if you are uncomfortable with anything that doesn't resemble Cranwell?
Leicester has multiple hard runways and an A/G that is bordering on being FISO, so you might prefer that. Although a friend did his RT there recently and they are still using the antiquated practical test rig ("Frequency A", "Frequency B" etc. type stuff I believe - too old for me!)
There's a chap at Sywell who does them too I think, on the modern computerised kit, I can look him up if you need. Huge runway, FISO service etc.
No idea about Nottingham's RT examiner, sorry. Runway(s) is/are nice though.
PreviousNext
Return to Student Pilots
Who is online
click here Login / Register
