Friday 24 May 2013 16:31 UTC
Latest FLYER headlines:
More news
Second Test
Here be cricket.
Moderator: nimbusj15
Paul Incognito
Sad Forumite
Second Test
Postby Paul Incognito » Tue Nov 30, 2010 1:47 pm
Can't wait, so thought I'd start the thread in anticipation....
Paul Incognito
Sad Forumite
Re: Second Test
Postby Paul Incognito » Fri Dec 03, 2010 2:06 am
Where are all the Aussie forumites when you need them?
Jwscud
Sad Forumite
Re: Second Test
Postby Jwscud » Fri Dec 03, 2010 8:23 am
All out for 245 having chosen to bat after having been 2/3 (or 3/2 if you're australian). Top stuff. Anderson has given the lie to those who said he couldn't bowl in Australian conditions...
Can't wait to get to Fremantle now - the banter is going to be high when we tie up!
I know it's a silly username. If you've met me, I probably introduced myself as Josh...
CaptChaos
Radial Wrangler
Re: Second Test
Postby CaptChaos » Fri Dec 03, 2010 10:24 am
Unbelievable but the Aussie implosion seems to be continuing. They are starting to look as hopeless as their scrum! (Not that we got the chance to push them off the park again)
CC
DA & FI
Please contact me via email.
nimbusj15
Soaring...
Re: Second Test
Postby nimbusj15 » Fri Dec 03, 2010 10:32 am
I look forward to waking up tomorrow morning to find England with 400 on the board.
PS I look forward to waking up every morning.
Jwscud
Sad Forumite
Re: Second Test
Postby Jwscud » Tue Dec 07, 2010 5:13 am
Aussies losing 6-64 this morning and England 1-0 up. We get to Fremantle this afternoon - serendipity!
Well done Swann; bad luck Stuart Broad, but Tremlett will hopefully seize his chance after his performance against Australia A.
CaptChaos
Radial Wrangler
Postby CaptChaos » Tue Dec 07, 2010 10:37 am
Well that was worth staying up for! The difference in teams was very apparent and I would assume the Aussies will go to the next stage of self-destruct in the break. You can never trust them not to make a contest of it but....
PS Nimbus please continue to achieve your ambition :)
CC
DA & FI
Return to Test Match Special and ODIs
Who is online
click here Login / Register
