Wednesday 22 May 2013 06:59 UTC
Latest FLYER headlines:
Beechcraft appoints Gama Support Services as ASC  -  Aerobility wants your used aviation equipment!  -  Wickenby to host Wings and Wheels, 15-16 June
More news
Varnishing A Wooden Propeller.
Forum rules
Flintstone
Sad Forumite
Postby Flintstone » Wed Jan 02, 2013 8:43 pm
I have to rub down and varnish my propeller. While doing so I plan to colour the tips too. Is it as straightforward as I think? Fine wet and dry, wipe down, spray in thin layers.
All hints, tips or advice gratefully received.
Ian Melville
Needs Help
Postby Ian Melville » Sun Jan 06, 2013 2:53 pm
You will need to re-balance it afterwards
Flintstone
Sad Forumite
Postby Flintstone » Sun Jan 06, 2013 9:48 pm
Thanks Ian.
So much for an easy job.
Charliesixtysix
Forumite
Re: Varnishing A Wooden Propeller.
Postby Charliesixtysix » Tue Jan 08, 2013 1:03 pm
May be worth a call to Rupert Wasey at Hercules Propellers.
http://www.hercprops.com/
matthew_w100
Forumite
Postby matthew_w100 » Fri Feb 01, 2013 1:43 pm
Ian Melville wrote:You will need to re-balance it afterwards
That's not hard. I have a nice simple prop balancer. It comprises a brass cup the same diameter as the hole in the middle of the prop (one inch, I thing) that fits into said hole and a spike as used by newspaper editors. The cup has a dimple dead centre of its base. Squeeze the cup into the prop hole and then sit it on the spike and you can readily see whether the prop is balanced, both longitudinally and traversely. Extra splodges of varnish are usually enough to get the prop back to perfect balance.
Return to Technical Discussion
Who is online
click here Login / Register
