Friday 24 May 2013 23:06 UTC
Latest FLYER headlines:
More news
De-icer
Forum rules
davey
Sad Forumite
De-icer
Postby davey » Fri Nov 02, 2012 11:01 am
When I was renting there was always a supply of aviation de-icer available for those early start cold mornings.
I'm told they are extremely expensive to buy, so the question is can car de-icer be used on aircraft ?
Tia.
Sometimes you're the pigeon and sometimes you're the statue...........
Paul_Sengupta
Season Ticket Holder
Postby Paul_Sengupta » Fri Nov 02, 2012 12:14 pm
Yay, the yearly subject! :D
The short answer is "yes, but keep it off the windows". It also could get really expensive!
As I understood it, aircraft de-icer is 45% propylene glycol, 5% isopropyl alcohol and 50% water. Car de-icer can be several things, with windscreen de-icer generally in the past being isopropyl alcohol.
Propylene glycol is used as a "bunny friendly" car antifreeze, so you may be able to obtain it that way.
Paul_Sengupta
Postby Paul_Sengupta » Fri Nov 02, 2012 12:26 pm
A quick google gives this:
http://www.marinemegastore.com/product.asp?pf_id=AFX_9_90760&src=GBASE
£13.90 for 5 litres, which if you mix it 50/50 with water, will cost that for 10 litres of de-icing fluid.
Haven't looked at isopropyl alcohol to mix in, but you used to be able to buy it on e-bay. Expect it'll work without it though.
Return to Technical Discussion
Who is online
click here Login / Register
