Saturday 25 May 2013 04:14 UTC
Latest FLYER headlines:
More news
Vne
Forum rules
Miscellaneous
Forumite
Vne
Postby Miscellaneous » Thu Oct 25, 2012 1:02 pm
Can anyone satisfy my curiosity?
Is there any margin designed in to Vne (as with SWL on cranes etc) or is it an absolute? By absolute I mean structural damage is possible from the specified Vne.
Although my understanding is that it is an absolute it appears to me this is not in keeping with most engineering practices.
Clarification would be appreciated.
Cheers,
Misc.
Skyhawk-N
Needs Help
Postby Skyhawk-N » Thu Oct 25, 2012 1:07 pm
dublinpilot
PFMS Team
Re: Vne
Postby dublinpilot » Thu Oct 25, 2012 1:26 pm
And I suppose as you approach it you need to be asking yourself if your ASI is accurate to within 10% in this extreme airspeed range which you rarely use.
Miscellaneous
Forumite
Postby Miscellaneous » Thu Oct 25, 2012 1:30 pm
Ideed, there are so many variables that are difficult to be precise about that leads me to belive that my assumption that it is an absolute must be wrong.
Misc.
dont overfill
Forumite
Postby dont overfill » Thu Oct 25, 2012 1:36 pm
A Beechcraft Duchess our club used cracked a side window during a VNE dive during a flight test. I was told it was not an isolated incident. The replacement was thicker!
I think I'll leave trying to find the limits to the test pilots.
D.O.
Genghis the Engineer
Forumite
Re: Vne
Postby Genghis the Engineer » Thu Oct 25, 2012 1:37 pm
When we design an aeroplane all of the various structural and stability considerations and determine a theoretical maximum speed which we call Vd. That will have structural and speed margins, but the margins will vary depending upon what factor it is.
In flight test we then try to get to Vd without anything nasty happening, but often we do reach a lower speed that nonetheless seems an acceptable maximum. The maximum speed set in flight testing is set to Vdiv.
Then Vne is set a margin below Vdiv. Almost invariably it's set to 90% of Vdiv.
Much the same is done for high performance aircraft with Mach number as well.
So saying that aeroplane's are tested to 110% of Vne is true, but simplistic. And also it took that when brand new and being flown by a test pilot, not years later flown by somebody without the detailed knowledge and backup that TP had. So particularly with older aeroplanes, Vne should really be regarded as a hard limit.
Lefty
Lost Cause
Re: Vne
Postby Lefty » Thu Oct 25, 2012 1:54 pm
It is expected that aircraft will be flown at VNE (I've flown mine to VNE many times on CofA air tests) - therefore there has to be a fairly generous safety margin - otherwise any aircraft - particularly an older aircraft, that is flown to or near VNE would be in immediate danger of coming apart. The manufacturers couldn't take on that liability.
Edit: Genghis has it!
Edit 2: It is surprisngly hard to get a "chunky" aircraft like a Cherokee six up to VNE - takes about a 4000 ft dive at full power and 45 degrees down bubble. Believe me - the pull out is alway very very gentle :wink: :wink:
Miscellaneous
Forumite
Postby Miscellaneous » Thu Oct 25, 2012 2:00 pm
Thanks Genghis, that makes sense. :thumleft:
Misc.
Paul_Sengupta
Season Ticket Holder
Postby Paul_Sengupta » Thu Oct 25, 2012 2:05 pm
dublinpilot wrote:in this extreme airspeed range which you rarely use.
I've seen some aircraft where the cruise speed (or was it max level speed?) is only 10 knots below Vne.
White Vans Man
Location: Tibenham - aka London Jimmy Stewart Executive Airport
Postby Rob P » Thu Oct 25, 2012 2:11 pm
Eye off the ball for a few moments in even a very gentle descent and the RV4 busts VNE (210mph) very convincingly. 75% Cruise at 8000ft is only 10 mph slower.
You do need to keep on top of it (as my mentor Hatz warned me)
Forum Diversity & Equality Officer (unpaid)
"We sleep soundly in our beds because rough men stand ready
in the night to visit violence on those who would do us harm."
- George Orwell-
Lefty
Lost Cause
Postby Lefty » Thu Oct 25, 2012 2:39 pm
Rob P wrote:Eye off the ball for a few moments in even a very gentle descent and the RV4 busts VNE (210mph) very convincingly. 75% Cruise at 8000ft is only 10 mph slower.
Very true - "slippery" aircraft can accelerate to & through VNE very easily. Mr Piper doesn't build very many in this category. :D
Paul_Sengupta
Postby Paul_Sengupta » Thu Oct 25, 2012 3:32 pm
My Bulldog's got a Vne of 185 knots. Or 213 mph. But you've got to be going seriously downhill to exceed it.
Forumite
Vne
Postby Genghis the Engineer » Thu Oct 25, 2012 3:48 pm
There are other requirements that there's a safety margin between the maximum level speed and Vne, and that it has a noticeable push to reach Vne. However those margins can vary quite a lot more between classes and types.
hatzflyer
Forum Addict
Re: Vne
Postby hatzflyer » Thu Oct 25, 2012 4:12 pm
The scenario that is likely to exceed VNE by quite some margin is a botched roll started at a very high entry and turning into a slit s.
Don't ask me how I know. :oops:
Need a LAA Inspector? go to http://www.jcairsafe.co.uk
Ben Twings
Forumite
Postby Ben Twings » Thu Oct 25, 2012 5:23 pm
One extra bit of food for thought:
Even though Vne is marked on an ASI as a fixed line, it is more related to TAS than IAS in so much as flutter will occur at a fixed velocity.
I believe that the margin from certification testing is good up to 10000', but above there you need to reduce Vne according to TAS.
Anecdotally, there are reports of RVs doing cruise descents from high altitude and getting the onset of flutter with the ASI safely below the red line, thankfully without disastrous consequences.
Also control surface balance is critical and repainting without re-balancing can have a significant effect on flutter margin.
Next
Return to Technical Discussion
Who is online
click here Login / Register
