Is anyone clued-up on the Magnesyn standby compass system? Apparently they were a popular factory fit in late 60's PA-28's. It's the first time I've come across one.
Is there any chance they could be used to 'feed' a RMI?
Wednesday 19 June 2013 09:05 UTC |
Latest FLYER headlines:
Forum rules
Next Topic | Previous Topic
• Page 1 of 1
Magnesyn standby compass?Eurofox taildragger group forming - West Sussex
I've not heard of them either but a quick google shows this:-
Also found this:-
PPL/IMCr/Night
Thanks, Simon. I've found quite a lot of information via Google, and it was used in a number of military a/c.
In the PA28 that I fly, the system is behind the panel in the rear baggage compartment, and the display is a fixed card compass display on the front panel. I'm not clued-up on RMI systems, but assumed that if the Magnesyn can feed a compass reading to a needle, then it might be possible to feed it to a moving card. What I need is to get up-to-speed on simple RMI kit to see if this is realistic. Eurofox taildragger group forming - West Sussex
If it is the same as I have come across in other aircraft you will have a remote Magnetometer feeding a display. MGL do a modern uncertified equivalent if you have a look at their website. If the above is correct it is likely to be proprietary, unless there is a port on the box in the boot
Rod1
Re: Magnesyn standby compass?Maybe something like the 60's G4B(Multi-engine) and G4F (Fighter) Selsyn systems?
But I would have thought these would have been a bit expensive and complex for GA Beagle Pup 150. flywales.flyer.co.uk
• Page 1 of 1
Return to Technical Discussion Who is onlineUsers browsing this forum: No registered users and 1 guest |
FLYER Exhibitions
Login / Register
