Saturday 25 May 2013 03:47 UTC
Latest FLYER headlines:
More news
Help pls with Tacho/EFIS installation
Forum rules
Doober2004
Junior Forumite
Postby Doober2004 » Mon Oct 01, 2012 12:58 pm
I'm installing an MGL Xtreme EFIS and RDAC in a Rotax 914 powered a/c and the aim is to retain a stand alone UMA electronic tacho. Previously when the tacho was installed in parallel with a FLYdat all was fine; when connected similarly with the RDAC no RPM indication is seen on either display .... disconnect the UMA and the EFIS/RDAC work as advertised. Has anyone else encountered and resolve something similar? Thanks in advance!
Frank Leopald
Sad Forumite
Postby Frank Leopald » Wed Oct 03, 2012 9:41 pm
Hi there Doober 2004. I thought I'd answer just to get you off 0. I read your post with interest and complete incomprehension about what you're talking about.
I'm struggling with this - MGLXtremeEFISRDACUMAFLYdatRDACnoRPMUMAEFIS/RDAC.
Apart from that it makes perfect sense......................................................not.
Word to the wise. Acronym rich posts are infra dig.
FL
Rod1
Forum Addict
Postby Rod1 » Wed Oct 03, 2012 10:24 pm
Which RDAC have you got? The bigger versions have a signal strength adjustment on a pot which may solve your issue re the MGL. Paul from P for A will be able to help.
Rod1
stevelup
Needs Help
Postby stevelup » Thu Oct 04, 2012 7:39 am
Frank Leopald wrote:I read your post with interest and complete incomprehension about what you're talking about.
Then there wasn't a great deal of point in replying...
They are part numbers of products - what was he supposed to do!
Rod1
Forum Addict
Postby Rod1 » Fri Oct 05, 2012 10:29 am
Doober2004
I realise this was your second post and that you did not get a very friendly reception. Have you solved your problem? If not, if you want help off line PM me (assuming you do not want to post hear which is fine to).
Rod1
peterh337
Postby peterh337 » Fri Oct 05, 2012 10:55 am
To help solve this you will need the full manuals on the equipment, with circuit diagrams (schematics) of the input circuitry if possible.
If it is a tacho then probably the transducer sends out pulses, rather than an analog value (voltage or current).
Some such transducers have open-collector outputs, with the required pullup resistor in one of the indicating instruments. If you connect additional indicators in parallel then - even if they are compatible at all - their input loading may overcome the pullup.
www.euroga.org
FAA CPL/IR
JAA PPL/IR
Return to Technical Discussion
Who is online
click here Login / Register
cron
