Wednesday 22 May 2013 11:05 UTC
Latest FLYER headlines:
NATS launches infringement awareness app  -  Beechcraft appoints Gama Support Services as ASC  -  Aerobility wants your used aviation equipment!
More news
Champion Spark Plugs
Forum rules
Waveflyer
Sad Forumite
Postby Waveflyer » Sun Jun 24, 2012 3:07 pm
A very interesting article appears in the June edition of the Cessna Pilots Association magazine which is not very complimentary to Champion Spark plugs.
It would appear that their fine wire plugs are failing at an unacceptable rate and that both fine wire and massive electrode plugs have a failure prone design of the internal silicon carbide resistor.
The author suggests that just about any other make of plug does not have these problems and criticises the arrogance of Champion who suggest we modify our engine operating procedures.
Perhaps those with unexplained engine glitches may need to look no further.
I use a dozen Tempest plugs which have been faultless.
Waveflyer
Colin G
Aviation Junkie
Postby Colin G » Sun Jun 24, 2012 3:44 pm
"You can make things happen, watch things happen or wonder what the **** happened"
peterh337
Postby peterh337 » Sun Jun 24, 2012 4:08 pm
Indeed; Champion have done a very dirty job on this issue, and have got away with it by the skin of their teeth.
Since 2003 I have had two batches of 12 RHM38S plugs (24 total) of which all 24 were way out of spec when they came out. Now I fly with the Tempest equivalents, which are a lot cheaper anyway.
www.euroga.org
FAA CPL/IR
JAA PPL/IR
G-BLEW
Boss Man
Postby G-BLEW » Sun Jun 24, 2012 5:52 pm
My next set of plugs will be Tempest fine wires.
Ian
The dirt is full of people who wanted bragging rights
Blog: Unicom Twitter: Flyer Magazine or me
Visit FLYER's Facebook page
IhaveBeenThere
Forumite
Postby IhaveBeenThere » Sun Jun 24, 2012 9:11 pm
Can someone advise where Tempest plugs are available to buy in the UK , please ?
Thanks
G-BLEW
Boss Man
Postby G-BLEW » Sun Jun 24, 2012 9:54 pm
Adams, Transair, AirParts etc.
Ian
Waveflyer
Sad Forumite
Postby Waveflyer » Sun Jun 24, 2012 9:58 pm
Mine came from Saywell Int, they were on special offer.
Waveflyer
SteveN
Sad Forumite
Postby SteveN » Wed Oct 24, 2012 2:07 pm
A little feedback to resurrect the above. Our TB20 when we purchased it last year had a tenancy to foul plugs. Champion massive electrode plugs were fitted and to be fair they didn't look like they owed us anything though they were not worn out. In March we changed to Tempest plugs before all the above came to light for no better reason than they were cheaper. The same massive plug specifications.
It may be coincidence but in the 7 months since then we have not had one occurrence of plug fouling.
peterh337
Postby peterh337 » Wed Oct 24, 2012 2:55 pm
I moved to Tempest finewires and over ~100hrs there has been no significant change in the resistance.
The work perfectly.
And they were cheaper than Champions.
www.euroga.org
FAA CPL/IR
JAA PPL/IR
beelzebub
Forumite
Postby beelzebub » Wed Oct 24, 2012 3:14 pm
If you have a Lycoming engine, make sure that it has Lycoming cylinders fitted. The Tempest massive electrode plug has the hex part lower down than on a Champion plug and you will potentially be unable to tighten it.
I came across an O360 a few weeks ago with replacement non Lyco (poss Superior?) cylinders and it was impossible to fit the new set of Tempest plugs to the top cylinders as you could not get a plug spanner on! We had to clean up the four best Champions to refit to the top plug holes. The bottoms were fine.
Quidvis recte factum, quamvis humile praeclarum.
Colin G
Aviation Junkie
Postby Colin G » Wed Oct 24, 2012 10:32 pm
50 hours on with Tempest fine wire plugs and not a sign of plug fouling.
Prior to fitting the fine wire plugs, if the engine wasn't leaned on the ground the plugs would foul up and need the big mixture pull to clean them up.
Awful Charlie
Forumite
Re: Champion Spark Plugs
Postby Awful Charlie » Wed Oct 24, 2012 11:27 pm
I've had Tempest fine wires fitted for the last 400hrs and they've been fine. Only drawback was that I needed to get my plug socket bored out a bit deeper to accommodate the slight extra length to the hex of the plug over a Champion as pointed out by beelzebub
You can sleep in an aeroplane, but you can't fly a house
Flyingmac
Sad Forumite
Postby Flyingmac » Thu Oct 25, 2012 8:21 am
I've got some of these. From the same era as my engine. I suppose I could have forked out more and bought ONE fine wire.
http://www.ebay.co.uk/itm/8-x-Champion- ... 0863118396
Every day, I thank God I'm not religious.
Chan eil aon chànan gu leòr.
Waveflyer
Sad Forumite
Postby Waveflyer » Thu Oct 25, 2012 8:39 am
Flyingmac wrote:I've got some of these. From the same era as my engine. I suppose I could have forked out more and bought ONE fine wire.
The plugs on ebay can work out to be very expensive if they don't work properly.
Waveflyer
peterh337
Postby peterh337 » Thu Oct 25, 2012 9:14 am
Ebay is full of fakes. I wouldn't buy anything "important" on Ebay unless it is trivial to verify.
www.euroga.org
FAA CPL/IR
JAA PPL/IR
Next
Return to Technical Discussion
Who is online
click here Login / Register
