Sunday 19 May 2013 15:03 UTC
Latest FLYER headlines:
More news
Pork
A place for gourmet aviators. Musicians are also welcome.
Moderator: Dave W
Monocock
Lost Cause
Pork
Postby Monocock » Sun Oct 07, 2012 8:45 pm
Ok, don't assume I'm a novice with cooking, it's one of my favourite past times.
Crackling: there really is a lottery situation with my success.... :evil:
I go dry, avec salt, with 240 degrees before the standard roasting temp and it sometimes fails. I try the high temp at the end and it sometimes fails. What's more annoying is that it sometimes works with these methods, really well.
Any proven theories?
Flyingfemme
Needs Help
Re: Pork
Postby Flyingfemme » Mon Oct 08, 2012 1:43 pm
Rayburn or Aga....the vented oven always seems to do the trick.
I intend to live forever.... so far, so good.
Peter Pan
Finally grown up!
Postby Peter Pan » Mon Oct 15, 2012 3:07 pm
I cook the pork til the meat is done, then carve the fat off it, salt the underside and back into the oven at 250 (Sandyford Range - it's like an Aga) :pig: :thumleft:
kingjame
Sad Forumite
Re: Pork
Postby kingjame » Sun Oct 28, 2012 6:41 pm
Dry, score, dry again, salt and then over the hob in oil take the crackling through the oil to make it partially burst open (being very careful with no kids about). Then crackling side down for half an hour at 240 degrees followed by 160 degress for the rest of the time minus 15 to 20 mins what they recommend. Check internal temp with a long pointy tempy thing and leave for 5 to 10 while the roasties get a good final blast.
Doing it right now and so far it is looking very good.
Edited to say it was cracking. Loving the irony of a townie giving a farmer advice on how to cook pork
AerBabe
Tailwheel Babe
Postby AerBabe » Thu Nov 08, 2012 2:39 pm
Getting good quality meat is a must...
I dry, score, dry again, rub in LOTS of oil & salt. Then into a really hot oven, crackling side up, for maybe 40 min and finish off at 160. If I've picked up a cheap joint I'll remove from the oven after stage one above and carve off the fat/skin before sticking everything back in the oven.
... or just buy a packet of pork scratchings from your local butcher & serve them on the side. :wink:
What if the Hokey Cokey IS what it's all about?!
Tours With Paws - Oxford colleges and parks
Flintstone
Sad Forumite
Postby Flintstone » Mon Jan 07, 2013 10:30 pm
gfry
Sad Forumite
Postby gfry » Thu Jan 24, 2013 12:50 pm
Aga all the way.
Score the fat, pour boiling water from the kettle over it, rub it with olive oile, rub it with salt.
Top over for 30 minutes, then cover with foil and move to the bottom oven for 24 hours. Come out like hog roast.
And as a sales pitch....my Gloucster Old Spots taste fantastic. PM or email for details
......ps my beef is also fantastic.
Blah Blah Blah
AerBabe
Tailwheel Babe
Postby AerBabe » Thu Jan 31, 2013 1:53 pm
Return to Flying Foodies' Forum (was Music & Musicians)
Who is online
Users browsing this forum: Samsonite and 1 guest
click here Login / Register
