Monday 20 May 2013 21:58 UTC
Latest FLYER headlines:
Major windfarm proposal threatens Popham  -  Manx Aero Club ends operations at Ronaldsway   -  Stapleford's new circuit pattern for twins
More news
'Submit' logs me out
To discuss anything which relates to the FLYER Airportal or the magazine
Talkdownman
Final Approach Track Man
Postby Talkdownman » Mon Mar 12, 2012 10:41 pm
After an age one-finger-typing something which might possibly be construed as ever-so-slightly constructive and sensible I click 'Submit' only to be logged out and lose my immaculate draft in the process.
Is anybody else having this problem?
Monocock
Lost Cause
Postby Monocock » Mon Mar 12, 2012 10:50 pm
Most days. Normally when only with EDGE, or less. With 3G it happens rarely and with WiFi it never happens.
Just highlight and click Copy before Submitting, at least it's saved then.
Talkdownman
Postby Talkdownman » Mon Mar 12, 2012 11:15 pm
Mike T wrote:I've a vague recollection this may have happened to others before.
Have you tried the usual first suggestion of clearing cache and cookies?
Thanks Mike but (as you will recall) I am a Mac disciple and don't have to worry about cash and biscuits. (Truth be told I wouldn't know where to start...maybe Mr Phillips will give me a steer...)
Anyway, my radar avatar is better than yours...
JonoH wrote:Just highlight and click Copy before Submitting, at least it's saved then.
Thanks, been doing that when I don't forget. Of course, it only happens when I forget...
...like now...
Talkdownman
Postby Talkdownman » Fri Mar 23, 2012 6:27 pm
Help please.
This is still happening.
'Submit', or 'Preview', logs me out.
Anybody...WTHIGO?
I think I'll give up posting...or trying to post...
Colonel Panic
Back on duty!
Re: 'Submit' logs me out
Postby Colonel Panic » Fri Mar 23, 2012 6:43 pm
TDM - does it happen if you use a different browser on the same machine? Are you able to try posting from a different machine?
(I'm no techie - just trying to narrow down the problem)
Keef
Just Keef
Postby Keef » Fri Mar 23, 2012 7:30 pm
I've just looked at the log, and can't see anything in there about your connections that's different from other Forumites.
Since it only does it to you, I'd suspect something in your router (if you have one) or in your browser.
As the Colonel says: does it do it with a different browser? Which one are you using now?
Keef
Moderatio in omnibus
GrahamB
Needs Help
Postby GrahamB » Fri Mar 23, 2012 8:03 pm
I have exactly the same problem with Safari on both of my Macs. As a result, I use Chrome for the forum, and Safari for everything else, including other forums using the same forum software!
Safari on iPhones/iPads seems fine.
GrahamB
Sent from my high horse
Colonel Panic
Back on duty!
Re:
Postby Colonel Panic » Fri Mar 23, 2012 8:26 pm
GrahamB wrote:I have exactly the same problem with Safari on both of my Macs. As a result, I use Chrome for the forum, and Safari for everything else, including other forums using the same forum software!
Graham - if that is the case then surely it points to something with Safari on your Macs (settings / cache / cookies / whatever) - there must be dozens of forumites using Safari without any issues :?
GrahamB
Needs Help
Postby GrahamB » Fri Mar 23, 2012 11:56 pm
I've tried all of those things to no avail. As I said, it only seems to happen with the Flyer forum, and not others.
I am aware that there are also other forumites with the same problem.
GrahamB
Return to Airportal and Magazine
Who is online
click here Login / Register
