Tuesday 18 June 2013 22:45 UTC |
Latest FLYER headlines:
Next Topic | Previous Topic
• Page 1 of 1
Donkey stops downwind.Last week I was doing circuits with a student in the RHS. Halfway through the detail I suggested my student change tanks as part of the pre landing checks. 10 seconds later the engine coughed and lost power. In addition to the usual restart tests I always urge my students to go back to the thing they did just before the failure and, if necessary, undo it so I looked down at the fuel cock (PA28) and sure enough it had been "overswitched" past the left tank and halfway to off. Stude turned it back, power came back on and that was the end of the drama.
Lessons learned, perhaps dont change tanks in the circuit, visually check if changing from Right to left in a PA28 and as I said earlier, possibly undo what you just did. Only 10 to go till I break Timbo's record! CPL IMC FI (A) and registering 9 on the bolometer.
Re: Donkey stops downwind.Live and learn!
Why was the student in the RHS? Frank Voeten
Use email please rather than PMs For information about my services (including aviation medicals) click this link ****Now also at Booker Airfield (High Wycombe) http://booker.aircrewmedicals.org *****
Re: Donkey stops downwind.Does that PA28 not have the metal tag/lug to prevent exactly that happening?
I would suggest lots MORE practice at changing tanks to ensure stude can do it correctly every time and not inadvertently select OFF. There are two ways to argue with a woman.
Neither of them work!
There is potentially one change of tanks you always do that could be more disastrous than any other change of tanks. If you mistakenly switching off the fuel just before power checks you might have enough fuel in a PA28 for a shortish power check and immediate take off and you could see your Lycoming delivering full power up to 200ft or so...
I have flown in ropey old club PA28s that may have once had some form of lug or detent, but no longer, and one had to be careful to avoid doing precisely this. It came as a massive shock when I first flew one in the USA to discover that one actually had to get past a detent to turn the fuel off. I know it's a silly username. If you've met me, I probably introduced myself as Josh...
Re: Donkey stops downwind.You were lucky. The only time I flew a 152 in the US it was held together by gaffer tape and string.
See the Barton accident thread for an example of precisely this: viewtopic.php?f=1&t=76326 If Timothy had his way, you would know me as Daniel.
Re: Donkey stops downwind.Out of interest, given the huge circuits that are normally taught at the Bushe, would you have made it to the airfield if the engine hadn't restarted??
Re: Donkey stops downwind.No. The circuit pattern is too wide.
The same thing happened to me during my night training in San Diego many moons ago.
Clapped out, old PA28 with worn out fuel selector so it spun all the way around to off. Luckily I relaised it didn't feel right, so managed to get the torch on the switch before the engine died. Guaranteed 100% iFree
Quite possibly sent from my Nexus 7 which cost 400 quid less than your iPad. Capitalisation is the difference between helping your Uncle Jack off a horse and helping your uncle jack off a horse
• Page 1 of 1
Who is onlineUsers browsing this forum: No registered users and 1 guest |
FLYER Exhibitions
Login / Register
