Wednesday 22 May 2013 00:35 UTC
Latest FLYER headlines:
Beechcraft appoints Gama Support Services as ASC  -  Aerobility wants your used aviation equipment!  -  Wickenby to host Wings and Wheels, 15-16 June
More news
Diamond DA40 – Engine Failure after takeoff
lenthamen
Junior Forumite
Postby lenthamen » Thu Mar 01, 2012 11:27 am
On Friday the 13th (January 2012) I successfully passed the PPL practice exam.
This is what happened on my first flight as a PPL holder a week later:
Details
Aircraft: Diamond DA40
Registration: PH-FLD
Date & Time: 20 January 2012
Place: Lelystad EHLE
Persons on board: 2
Summary
Diamond DA40 Diesel got an Engine Failure just after takeoff while performing a touch & go landing.
Description
At 16:10 we departed Lelystad for a local flight. A student pilot, who I knew from the PPL flight training,
joined me.
During the preflight and runup checks there was no indication of a possible problem. ECU test went fine.
After departing from RW23 we made a right turn and flew to the Northern direction.
45 minutes later we flew back to the airport. Since there was 30 minutes left before the airport closes,
we decided to practice some touch&go’s.
The third touch & go was a “short field landing”. Approaching the runway with 65kts and about 30%
power selected. The flaps where in “landing” configuration. We touched down at the beginning of the
runway with power idle. After touchdown flaps were set to “Take/off” and power to 100%. Shortly after
takeoff (about 30ft AOL) the engine suddenly stopped. It felt like the engine was switched off just like a
regular shutdown. Before the incident the engine sounded fine, and no messages on the annunciator
panel.
While flying above the runway, we could safely land on the remaining runway.
After touchdown I applied maximum brakes, and notified the Tower that we had an engine failure. We
halted just before the end of the runway. The plane behind us on final had to go around as we were
blocking the runway.
Two marshaller vehicles came to us and assisted with pulling the aircraft off the runway.
We brought the aircraft back to the hangar and notified the Diamond Flyers foundation about our
unfortunate experience.
lenthamen
Junior Forumite
And the reason why it happened...
Postby lenthamen » Thu Mar 01, 2012 12:52 pm
... And the reason why I got this Engine Stop was this:
The engine turbocharger hose inner layer separated from the outer layer, causing the engine to "suck vacuum" and consequently led to in-flight shutdown...
Diamond issued an Airworthiness Directive to have all turbo hoses replaced.
See picture below, where you can clearly see the inner hose being separated from the outer hose...
Keef
Just Keef
Postby Keef » Fri Mar 02, 2012 11:12 am
You were very fortunate that it happened when there was a runway to hand!
Keef
Moderatio in omnibus
chipmeisterc
Forumite
Postby chipmeisterc » Mon Mar 12, 2012 2:39 pm
+1 good job on the outcome good job it happened where it did!!
Return to It happened to me
Who is online
click here Login / Register
