Thursday 23 May 2013 15:16 UTC
Latest FLYER headlines:
More news
Infringement
A strictly Anonymous Forum designed to allow you to share those moments in flying that caused you concern. No names, no pack drill. You can post without registering a username. Existing registered users can log out to post if they wish
Anon
Anonymous poster
Infringement
Postby Anon » Thu Jan 19, 2012 9:30 pm
Hi,
I visited Panshanger a few weeks back, and in my efforts to concentrate on the noise abatement circuit, got very close to the Luton Zone where it drops to ground level:
A couple of questions:
1. Would you consider this an infringement?
2. Should I 'fess up and report it, in the hope that this makes it less serious, or just keep schtum and hope? Assuming I 'fess up, how do I do that? Call Luton?
Regarding point 2, I seem to remember reading that in the States they have a scheme where you submit a form, and that renders you effectively immune from prosecution regarding the event.
Would appreciate your thoughts.
Skyhawk-N
Needs Help
Postby Skyhawk-N » Thu Jan 19, 2012 10:38 pm
Keef
Just Keef
Postby Keef » Fri Jan 20, 2012 2:04 pm
If you got "very close to it" that's not an infringement. If you went into it, it is.
In the latter case, since a few weeks have elapsed, I'd wait to see if they contact you. Had it been yesterday, I'd have called them to "discuss" it.
There's no "fess up and escape prosecution" here, but the CAA is normally sensible about such matters.
Keef
Moderatio in omnibus
fuzzy6988
Sad Forumite
Postby fuzzy6988 » Fri Jan 20, 2012 8:29 pm
I think no, but it was a close shave! Based on your diagram I can't see traffic inside the CTR being disrupted in this case anyway.
I guess one thing I try to bear in mind myself is to remain within gliding distance of the field.
Non-standard "noise-abatement" circuits should not take you outside the ATZ... if it does the ATZ needs enlarging. :)
Mark R
Forumite
Postby Mark R » Fri Jan 20, 2012 9:05 pm
Probably not an infringement, but the initial join looks a bit suspect though. With a right-hand turn against the circuit direction to turn back onto the deadside.
If someone else was joining from the NE at the same time things might have got a bit 'interesting'.
Skyhawk-N
Needs Help
Postby Skyhawk-N » Fri Jan 20, 2012 9:38 pm
NATS GA Lead
NATS
Re: Infringement
Postby NATS GA Lead » Sat Jan 21, 2012 1:02 pm
I don't think Panshanger has featured in a NATS investigation for a few weeks now. Your track as represented on the chart would probably not generate a second glance from the TC Luton controller. If you let me have the date/time I will check the radar replay and try and capture a shot of what it looked like from our end.
Jonathan Smith
NATS General Aviation Lead
D: 01489 612645
M: 07966 505088
E: jonathan.smith@nats.co.uk
Mailbox 22, Room 2103, Sopwith Way,
Swanwick, Hampshire SO31 7AY
http://www.nats.co.uk
Anon
Anonymous poster
Postby Anon » Sat Jan 21, 2012 10:03 pm
PM sent.
Thanks Jonathan.
Pete S
Arrer Driver
Postby Pete S » Sun Jan 22, 2012 11:12 am
'Er I think I may have gone through a red light, Officer: Here are the details of the time and place so you can have a look at your CCTV.....' :wink: :wink:
Primum non nocere..
RickRouse
Forumite
Postby RickRouse » Sat Feb 04, 2012 1:39 pm
I have to say that NATS are excellent when dealing with private pilots who make a genuine mistake and contact them. I met Jonathan Smith when he coordinated a tour of Swanwick a few years ago and was a fantastic education, brought me more confidence in my flying and reduced the 'us and them' attitude I had.
If anyone gets the opportunity to do the tour, I'd heavily recommend it. They give a good talk on infringments and how they happen.
Return to It happened to me
Who is online
click here Login / Register
cron
