Sunday 19 May 2013 15:47 UTC
Latest FLYER headlines:
More news
What would you do?
Morley
The Third
What would you do?
Postby Morley » Fri Jul 15, 2011 10:59 am
Yesterday an aircraft started up and was readability 1 to 2 on occasion but mostly carrier wave only. I commented to tower that he was readability 2 also but the a/c took off anyway. Predictably 5 minutes later the frequency was interrupted every 30 secs or so by carrier wave as he was trying to get back. In the end it landed safely but in my opinion should not have taken off in the first place with a defective radio. Clogging up the frequency as he did was potentially dangerous. Views? (other than the radio/non-radio debate which is an entirely different issue, as radio is mandatory here)
CPL, IMC, FI(A)... And a beige devil.
Jim Jones
Lost Cause
Postby Jim Jones » Fri Jul 15, 2011 11:02 am
In a radio mandatory zone I would treat radio malfunction in the same way as a failure of a magneto. Taxy back and shut down, call the maintenace guys.
Frequently misunderstood
greggj
Sad Forumite
Re: What would you do?
Postby greggj » Fri Jul 15, 2011 12:03 pm
My personal opinion is that in the 21th century radio should be always required, regardless. So no go without it.
P/UT
iOS developer
<-- (yet another) ppl blog.
Prob75 this msg was sent from iPad, not any toy.
Gertie
Senior Forumite
Postby Gertie » Fri Jul 15, 2011 12:22 pm
I wouldn't go without it it. But that's because (a) I rent, so I'd just complain and ask for another aircraft, and (b) I fly from a field where non-radio isn't allowed anyway.
If I flew my own aircraft from my own strip that might be another matter.
GrahamB
Needs Help
Postby GrahamB » Fri Jul 15, 2011 12:28 pm
greggj wrote:My personal opinion is that in the 21th century radio should be always required, regardless. So no go without it.
Why should radio always be required? I'd like to understand your reasons for thinking that.
GrahamB
Sent from my high horse
fuzzy6988
Sad Forumite
Postby fuzzy6988 » Fri Jul 15, 2011 2:56 pm
In a radio mandatory zone I would treat radio malfunction in the same way as a failure of a magneto. Taxy back and shut down, call the maintenance guys.
Seconded or use COM2. The mandatory zone is there for a reason (presumably too many airproxes in the past from non-radio traffic).
But it also depends what area I operate in.
If it's a remote private strip, low traffic density, and good weather all round then, even though I prefer to use the radio to make the odd air-to-air traffic call, I'm not fussed if it was broken. I just enjoy the flight.
But take London. The airspace is congested. Most likely I wouldn't fly if it was broken. And I can't get a clearance to enter CAS/ATZs without it.
I've got a backup hand-held just in case as well.
greggj
Sad Forumite
Postby greggj » Fri Jul 15, 2011 3:06 pm
GrahamB wrote:Why should radio always be required? I'd like to understand your reasons for thinking that.
It makes sense to be able to communicate always. Radios are not either expensive nor heavy these days, I see no reason not to have it.
P/UT
iOS developer
KNT754G
Needs Help
Postby KNT754G » Sat Jul 16, 2011 8:10 am
You say radio is mandatory, but is this A/G, AFIS or ATC? What can be enforced could make a difference.
That aside, if radio is mandatory and strength 5 two way cannot be achieved then it is a no go decision.
There are two ways to argue with a woman.
Neither of them work!
Keef
Just Keef
Postby Keef » Sat Jul 16, 2011 6:10 pm
Cue Rob P...
No, you don't need to be able to communicate always. It's nice to have, but radio doesn't make aeroplanes fly.
If you have one radio and it doesn't work, you have to decide whether or not to fly. That's the pilot's call. I regularly fly with the radio turned down anyway, because there's nobody to talk to (or nobody I want to talk to). Sometimes I switch it to 121.5.
I happen to carry a handheld because I used to be in the habit of flying in controlled airspace. In the 20-odd years I've had it, the only times I've used it in anger have been to listen to ATIS and to call for start clearance on an IFR trip. An IFR-equipped aeroplane will have two COM radios: on occasions we've used both of them at once - P1 talking to tower for approach clearance, PNF talking to area control to sign off.
Keef
Moderatio in omnibus
William
Forumite
Postby William » Sun Jul 17, 2011 12:22 pm
I suppose it depends what your starting point is - followed by where you are heading.
From Bournemouth - no decent communication with tower or ground means I don't even begin to taxi. From the middle of nowhere I probably wouldn't even know the radio wasn't working until I got airborne and tried to call someone. If that happened, however, and I was heading somewhere where I needed clearance, I would be heading back to my departure point at the first opportunity.
In a time of universal deceit - telling the truth is a revolutionary act. (George Orwell)
ROG
fORUM aDDICT
Postby ROG » Thu Jul 21, 2011 6:45 am
If flight was really necessary--unlikely--I would use my transceiver (which i always carry in case of a radio failure ) otherwise would cancel and get fixed.
PEOPLE WITH DODGY RADIOS ARE A MENACE TO THEMSELVES AND OTHERS.
Pete S
Arrer Driver
Postby Pete S » Thu Jul 21, 2011 11:33 am
Agree with ROG: an Icom in the flight bag is an essential: However, performance of a tranceiver is not as good as A/C radio and in similar situation I wouldn't have taken off just for a jolly, though might have if it was a case of a return trip to base.........
Primum non nocere..
greggj
Sad Forumite
Postby greggj » Thu Jul 21, 2011 12:05 pm
ROG wrote:If flight was really necessary--unlikely--I would use my transceiver (which i always carry in case of a radio failure ) otherwise would cancel and get fixed.
+1
P/UT
iOS developer
Flyingmac
Sad Forumite
Postby Flyingmac » Thu Jul 21, 2011 12:30 pm
greggj wrote:. Radios are not either expensive nor heavy these days,
????????????? http://www.gps.co.uk/Transceivers/Garmi ... 2-261-273/
Every day, I thank God I'm not religious.
Chan eil aon chànan gu leòr.
greggj
Sad Forumite
Postby greggj » Thu Jul 21, 2011 2:32 pm
Relatively :)
Compare that with the aircraft cost.
P/UT
iOS developer
Next
Return to It happened to me
Who is online
click here Login / Register
