Thu Apr 28, 2016 9:40 am
#1451802
Deleathalisation - word of the week!
FL
FL
Frank Leopald wrote:Deleathalisation - word of the week!
FL
terrybarr wrote:A suggestion I heard many years ago but I have never seen implemented. Three rows of paving slabs spaced to suit the track of the aircraft wheels. Lay the so as to slope down to the hangar door. Then have a winch so that you can pull the aircraft uphill into the hangar single handed with no trouble.
PeteSpencer wrote:We have a (no longer used) hand winch to drag the a/c into the hangar. It was so low geared that it needed zillions of turns to get the a/c in.
We now use a golf buggy with custom made bi-sprung tow bar which does the trick very nicely.
Winch retained in case buggy battery goes flat(never has so far).
Charles Hunt wrote:Is this a DIY project, or are you paying a contractor?
A good, well compacted foundation is probably more important than the concrete on top.
What is the current floor/base?
For hand laid concrete bays 4m x 4m is probably as big as you can sensibly go, often laid in chequerboard or 'hit and miss' bays. You will have to set screed rails or timbers to the correct finished height, then place the concrete a bay at a time. Remove the screed rails from the first set of bays, re-position as necessary and then do the infill bays.
75 to 100mm of concrete should be plenty over at a guess 150mm of broken concrete or brick rubble with a skim of type 1 to give a smooth surface, or all type 1 sub base well compacted with a roller or wacka plate. Put a layer of polythene as a slip layer between there base and the concrete.
The concrete will also need to be well compacted either by ensuring a surcharge in each bay and using a vibrating beam to compact it and strike it to the finished level, or using a poker vibrator.
Working up the scale you can have a rough tamped finish, skip float and hand trowel, or power finish. For the power float you would probably need a specialist company to lay and float the whole area in one go, this would not be compatible with a DIY 4m bay approach.
Trent772 wrote:ask them to wet it on site, lays much better.
Trent772 wrote:4 inches is fine.
I have 2 40' x 30' bases at Beckwithshaw near Harrogate that you can have if you want.
First one was condemned by the council, the second one was robbed by the farmer falling out with me.
Concrete is expensive btw........
Get it with fibres in, it is more robust and ask them to wet it on site, lays much better.
Last concrete was Lafarge Agila, which is beautiful stuff. Pumped into the workshop and woodstore. Self levelling, no dust after 5 years - a good bit more expensive but - Oh My, well worth it for indoor workshop stuff. Not worth it for a hangar.
Just saying like...
