Fri Nov 20, 2015 1:31 pm
#1419300
I'm chasing this down as well, as I'm seriously thinking about putting a KT74 in my Sportcruiser.
Mendelssohn told me today that the current KT74 has the Trig 3.4 firmware, which does support ADS-B out with SIL=SDA=0, as required. Whether that applies to older models of KT74 is unknown, so for a start I suggest checking the firmware revision level. I am still trying to get to grips with the relationship between the TT31 and KT74. The latter must have some additional/different firmware to support the number buttons but beyond that all the evidence I have so far is that it is a TT31 in disguise.
Next is the GPS capability. As I understand it, ADS-B out only works if your GPS supports (and is receiving) EGNOS WAAS satellites.
I think this trial, with its distinctly odd parameter requirements, has put the cat amongst the pigeons, with transponder manufacturers scrambling to keep up (or not) and rather a lot of misinformation out there.
John
