matthew_w100 wrote:All right - I'm being petulant! And a bit silly. I'm having another go. You had said there was a work-around for the cd thing - is there anything other than the virtual cd trick (which is more trouble than just putting the cd in)?
The legit way is to order a USB license key. You then leave that stuck in the back of your machine. The dodgy way is the virtual CD trick.
You only have to do it once though, so it's a brief bit of pain for subsequent peace and quiet.
It doesn't seem to like my throttle quadrant now - i have to reverse the direction for the throttle axis (but not the mixture) and it won't let the rpm drop much below 1000 on the ground or 1700 in the air. Which made landing "different".
When in the 'calibration' screen where you can see the little graphs for each input, cycle all the controls through their minimum and maximum values. X-plane now knows the correct min-max values. Again, you only need to do this once.
Where do aeroplanes come from?
Your best bet is to join the X-Plane forums here:-
http://forums.x-plane.orgJust had a quick look - there are 2918 aircraft available for download. There are loads of really good free ones, and also some stunning pay ones. Best strategy is to look at ones that have had more than a 1000 downloads and five star on the reviews, but you can always read the comments as well.
Thank you for your forbearance
Last chance on the grumpiness
