Thursday 20 June 2013 00:24 UTC
Latest FLYER headlines:
Aeroplane rental service launches in America  -  Schneider Trophy Air Race celebrates 100 years  -  HIAL passenger numbers up by 8,000
More news
Cloud levels
Presented by:
markpodbery
Forumite
Cloud levels
Postby markpodbery » Thu Jan 03, 2013 12:16 pm
I am sure this has been asked a million times and there is no answer, but I can't seem to find anything much after a search!
Is there anyway or website that shows the thickness of the cloud levels to be able to climb above?
Thanks
Mark
Merlin83b
Forum Addict
Re: Cloud levels
Postby Merlin83b » Thu Jan 03, 2013 12:47 pm
The 215 shows tops if below FL100, which might be what you need. If not you should go and look at Peter Holy's website - lots of information on assessing cloudy weather there.
If Timothy had his way, you would know me as Daniel.
Irv Lee
Beyond Hope
Re: Cloud levels
Postby Irv Lee » Thu Jan 03, 2013 12:53 pm
one of the most misunderstood features of Metform 215 is the cloud notation. Given
BKN 020-040/070-090 and asked - are you likely to be in cloud at 6000'? - most (>90%?) pilots I meet will wrongly say no, that is between 2 layers
Irv Lee -JAA / UK CAA / SA CAA Approvals (R/T & Flight)
Confused by Rules?: GA-FAQ, Pre-Preflight Checklist etc: http://www.higherplane.co.uk
UK GA Twittering not Tw@ering: irvleeuk (http://twitter.com/irvleeuk)
rats404
Forumite
Postby rats404 » Thu Jan 03, 2013 1:59 pm
The 2012 version of "Get Met" has a number of explanatory notes.
http://www.metoffice.gov.uk/media/pdf/e ... 012_V2.pdf
Page 15 covers the 215. I have to say though, that it could have been written more clearly, with a worked example of a 215.
Jwscud
Sad Forumite
Re: Cloud levels
Postby Jwscud » Thu Jan 03, 2013 2:30 pm
I wouldn't rely on cloud tops in the 215. I look fairly regularly at this time of year trying to find acceptable VMC gaps between layers to avoid icing conditions, but have regularly found even the forecast ranges a bit shaky. Don't rely on finding VMC - always have a backup plan, especially when the freezing level is below MSA.
I know it's a silly username. If you've met me, I probably introduced myself as Josh...
GrahamB
Needs Help
Postby GrahamB » Thu Jan 03, 2013 2:51 pm
The GFS Skew-T diagrams available here can be helpful in anticipating where tops and layers might exist, once you learn how to interpret them. There's plenty on the web that explains them.
You get to them via 'Weather Maps > Expert Charts' then top right 'GFS' under 'Soundings'
GrahamB
Sent from my high horse
Irv Lee
Beyond Hope
Postby Irv Lee » Thu Jan 03, 2013 3:54 pm
rats404 wrote:The 2012 version of "Get Met" has a number of explanatory notes.
Yes but even if they knew where to look, they wouldn't, as they are absolutely sure they know what it means, so 'no need'
Pugh Pugh
Forumite
Re: Cloud levels
Postby Pugh Pugh » Thu Jan 03, 2013 9:00 pm
OK Irv, on the basis that "there are no stupid questions, only stupid answers", and in the hope that you will therefore be gentle with me, could you please explain your example so that I may check my understanding of it now rather than at FL60 in icing cloud (or not!)
Lucky in life, unlucky in computery stuff.
Irv Lee
Beyond Hope
Re: Cloud levels
Postby Irv Lee » Thu Jan 03, 2013 9:41 pm
just 'parse' around the '/' - left of it is a base or base range, right of it is the top or top range - so BKN 020-040/070-090 would not be two layers with a gap in between, it would be a base between 2000' and 4000', and tops would be between 7000' and 9000'. They don't have to have 2 bases or two tops, levels like 002/015 is sometimes seen when radiation fog is supposed to lift into low stratus, meaning 200' base, 1500' tops - the key is to know that the '/' divides base and top - but I'm struggling to remember anyone knowing that 'straight off'
Cumulo-nimbus
Forumite
Re: Cloud levels
Postby Cumulo-nimbus » Fri Jan 04, 2013 8:07 am
Bluddy obvious, ain't it. eh? Anyhow, that's how I've always read it.
Banking: a licence to create money. Let's be out of the bureaucratic monstrosity; and EASA too!
Pugh Pugh
Forumite
Re: Cloud levels
Postby Pugh Pugh » Fri Jan 04, 2013 8:24 am
Thanks Irv. My understanding was correct, but your comment of 90% of pilots not necessarily understanding the "bluddy obvious" (thanks Cu-Nim, not) introduced an element of doubt. Hopefully you've also cleared that up for others who may have had the same doubts, but who were reluctant to admit it because of patronising and unhelpful comments. Cheers.
smithgd
Forumite
Postby smithgd » Sat Jan 05, 2013 12:00 pm
The met office F215 form has a user guide on their web site (including a worked example):
http://www.metoffice.gov.uk/aviation/ga-briefing-services/briefing-charts-details
My other aircraft is unmanned :-)
DavidC
Forumite
Re: Cloud levels
Postby DavidC » Sat Jan 05, 2013 12:53 pm
Anyone know if the GFS Skew-T diagrams mentioned above will continue to be available for Filton, now that the airport has closed?
low&slow
Forumite
Postby low&slow » Sun Jan 06, 2013 5:28 pm
No reason why not, it's just a forecast for a particular lat/long & not associated with the airfield.
There's a better tool at this website. Select your date & time & the SkewT radio button under Info Popup & then right click on your location. You can see forecast cloud amount & heights on the left hand y-axis.
Return to GA Discussion
Who is online
Users browsing this forum: Google Feedfetcher and 10 guests
click here Login / Register
