Tuesday 21 May 2013 19:22 UTC
Latest FLYER headlines:
Beechcraft appoints Gama Support Services as ASC  -  Aerobility wants your used aviation equipment!  -  Wickenby to host Wings and Wheels, 15-16 June
More news
Interesting case: Leeds Crown Court
Presented by:
Old Pilot
Forum Addict
Postby Old Pilot » Thu Jan 03, 2013 10:26 pm
I have to agree with you on the Jetranger Rotorboater.
After the R22 it is a pleasure to fly and the auto is more gentle than the Robbo. Trouble is you need a lot more money to obtain a PPL on a machine like that.
Genghis the Engineer
Forumite
Postby Genghis the Engineer » Thu Jan 03, 2013 10:37 pm
Flintstone wrote:
Genghis the Engineer wrote:...the holes in the swiss cheese...
That's it, you're now on The List.
Sorry, but my hobby is writing papers for academic aeronautics journals. You have to expect the odd slip. I'll try not to do it again.
Flintstone
Sad Forumite
Postby Flintstone » Thu Jan 03, 2013 11:13 pm
Welllllll, alright then. I'll let you off with twelve months probabtion if you join me in my campaign to eliminate that bl00dy hackneyed old phrase from the aviation lexicon, particularly the CRM syllabus. It's a flawed analogy anyway.
Have you ever seen a block of swiss cheese with a hole all the way through? No. So, take a block of swiss cheese. Slice it up and take each hole in a slice to be an error. Yes, if you line a few slices up there's a clear run through but if you replace the other slices the hole no longer runs all the way through. Translate this into errors and what you're saying is that if you make more errors an incident won't occur.
Didn't think it through, did they? :D
Jwscud
Sad Forumite
Re: Interesting case: Leeds Crown Court
Postby Jwscud » Thu Jan 03, 2013 11:24 pm
I have always preferred "error chain" myself. Mainly because the best thing for Swiss Cheese is a Fondue, and Gruyere is a very strange place. Just take the local cafe for a start.
I know it's a silly username. If you've met me, I probably introduced myself as Josh...
Timothy
CLEAR PROPS!!!
Postby Timothy » Fri Jan 04, 2013 10:18 am
Flintstone wrote:Slice it up and take each hole in a slice to be an error. Yes, if you line a few slices up there's a clear run through but if you replace the other slices the hole no longer runs all the way through. Translate this into errors and what you're saying is that if you make more errors an incident won't occur.
You clearly misunderstand the analogy, which is probably why you reject it.
Each slice is a layer of process, equipment or procedure designed to prevent an accident.
Each hole is an error or oversight. There can be many holes in a slice, or no holes in a slice.
The more slices, the less likely to be an accident (so if you have five engineers checking a piece of work, it is less likely to have a failure than if two do).
The more holes per slice the more likely (so, if one engineer is partially sighted, another has faked his qualifications, another is dyslexic and drunk etc the more likely a failure.)
I don't really see what's wrong with the analogy, except that it's now boring (in the ennui sense, not drilling a hole through.)
Timothy
Not sent from my iPad.
Oxo147
Forumite
Postby Oxo147 » Fri Jan 04, 2013 10:35 am
So if you add some pickle to the holey cheese slices, then it will fill the holes and everything will be alright?
Paul_Sengupta
Season Ticket Holder
Postby Paul_Sengupta » Fri Jan 04, 2013 11:02 am
Oxo147 wrote:So if you add some pickle to the holey cheese slices, then it will fill the holes and everything will be alright?
I don't understand, wouldn't you then end up in a pickle anyway?
Oxo147
Forumite
Postby Oxo147 » Fri Jan 04, 2013 11:09 am
Ah, quite so. Maybe mayonnaise or Dijon mustard would be better.
Paul_Sengupta
Postby Paul_Sengupta » Fri Jan 04, 2013 11:12 am
Though I'm guessing you'd still have people who couldn't quite cut the mustard.
Leaky Mick
Forumite
Postby Leaky Mick » Fri Jan 04, 2013 11:16 am
I can't think of any grate jokes.
Ex-plumber. Eats burgers and flies.
JonEBgood
Forumite
Postby JonEBgood » Fri Jan 04, 2013 11:34 am
What cheese do you use to tempt a Grizzly Bear down from the mountainside?
Camembert
for anyone who has not heard it...
"Cam-on-bear"
:lol:
JonEBgood
Flying is the second greatest thrill known to man.
rkgpilot
Forumite
Postby rkgpilot » Fri Jan 04, 2013 11:53 am
Oxo147
Forumite
Postby Oxo147 » Fri Jan 04, 2013 12:18 pm
OK, enough with the cheese jokes,
If we stop now, nobody will cheddar tear.
Keef
Just Keef
Postby Keef » Fri Jan 04, 2013 12:33 pm
Many more cheesy jokes and there may be a case for moving this thread to the Gourmets Forum.
Jim Jones
Lost Cause
Postby Jim Jones » Fri Jan 04, 2013 12:52 pm
I've only read the news reports, and the case is against an alleged dodgy instructor/examiner.
What would be the implications of successful prosecution? Would the pilot be deemed unqualified and hence impact on insurance payouts? Graham Hill and Colin McRae had irregularities in their paperwork which seriously affected their families finances, and AIUI relieved the insurance companies of a need to pay out in full.
Frequently misunderstood
PreviousNext
Return to GA Discussion
Who is online
Users browsing this forum: alexh, asthecrowflys, Bing [Bot], Capt Edmund, David Wood, fatman, mally, mick w, muffin, rats404, stevfire2, trice1921, wigglyamp and 42 guests
click here Login / Register
