Yep, I regularly get asked at Bournemouth if I can accept an Immediate departure while aircraft are on final, it's my call if I decide I can. Airmanship rules OK.
Sometimes you're the pigeon and sometimes you're the statue...........
davey wrote:Yep, I regularly get asked at Bournemouth if I can accept an Immediate departure while aircraft are on final, it's my call if I decide I can. Airmanship rules OK.
That's not quite the same as the uncontrolled environment. An ATC unit has the authority to vary or dictate the sequence. The reason we ask you is, more often than not, to alert you to the fact that you'll need to get a wriggle on once the clearance is forthcoming and, of course, for you to assess if you're happy to line up and commence your take off without delay.
Which is the same as the roundabout situation Paul S describes. With an aircraft on finals, whether 'cleared' by ATC or not, the only person who can judge whether its safe to line up and take off safely is the pilot of the departing aircraft. The landing aircraft has right of way, and can't land on a runway occupied by another aircraft. In an extreme situation, as long as the departing aircraft is airborne before the landing aircraft touches down, fine and dandy. Judging this from the landing aircraft is down to experience and whether the pilot is happy to continue with a potentially late go around and have fairly close spacing on finals.
Davey is right; Airmanship does rule, but it's just a shame nobody seems to teach it properly these days
Never in the field of aviation forums has so much bolleaux been written by so many who know so little.....
The landing pilot has to know that his existance is known of, otherwise his perception of the "airmanship" may be flawed. "G-XX lining up for immediate, one on final visual" might help.
The 6 P principle
Proper
Planning
Prevents
Particularly
Poor
Performance
Crash one wrote:The landing pilot has to know that his existance is known of, otherwise his perception of the "airmanship" may be flawed. "G-XX lining up for immediate, one on final visual" might help.
Absolutely correct. Works well everywhere to put the mind at rest. "G-XX Downwind 27 right hand to land. Contact one ahead."
Thank you D.O. However I have a slight issue with "Contact" one ahead. I certainly don't want the "contact" to be physical. I doubt whether I would "contact" the landing a/c in the same way that ATC might request me to (frinstance) "Contact Edin tower on xxx.xxx". Or am I being pedantic? Thoughts on "Contact" versus "Visual", please. G-UR, US at this time, see you later with the bickies, Happy new year.
The 6 P principle
Proper
Planning
Prevents
Particularly
Poor
Performance
I don't know if "contact one ahead" is in the CAP, but I've heard it used in many places, and use it myself. I treat is as an abbreviation for "have visual contact with..."
