Cirrus SR20 whats it like?
PostPosted:Fri Apr 01, 2011 4:32 pm
by cmdr114b
I have been looking at the SR20 and wondered if anyone here as any experience of this plane.
Can you use it 4 up with limited fuel and baggage?
Anything not to like?
Re: Cirrus SR20 whats it like?
PostPosted:Fri Apr 01, 2011 5:09 pm
by Flyin'Dutch'
Runway and climb performance are lacking when loaded.
Nice enough but airframe really needs the bigger engine; don't know what the ratio is but suspect 20/22 is more thab 1:10.
by G-BLEW
Great aircraft, but take a look at w&b as 4 up + fuel + baggage will be interesting. Useful loads vary depending on equipment and tend to run between 360kg and 410kg. Check MAUW performance if you are based somewhere short.
Ian
PostPosted:Fri Apr 01, 2011 5:16 pm
by Dave Phillips
Likes runway at MAUW.
Thirsty when in 'go fast' mode.
Otherwise, a nice aircraft to fly.
PostPosted:Fri Apr 01, 2011 7:43 pm
by Pete L
On brief experience, the kit is amazing and it's the most wife-pleasing a/c of them all - very tempted with a share. But I preferred the C182 for it's air of brick sh*thouse and it's short field performance.
PostPosted:Sat Apr 02, 2011 7:54 am
by Jonzarno
Which model (G1,G2 or G3) and which avionics package (ARNAV, Avidyne or Garmin Perspective) are you looking at?
PostPosted:Sat Apr 02, 2011 11:31 am
by baldwinm
I fly a SR20 based at Blackpool (another part of the same group that Bloomer tried).
As stated there is a group rule on flying from grass - it does seem to need a lot of power to make headway when taxiing on grass but I would imagine dry, short (the grass not the runway length) grass should be fine.
It's the generation 3GTS version with all the toys (Avidyne, 2*GNS430W,Terrain, Traffic, STEC 55X autopilot, Stormscope). It will take my family (two slimmish adults & two teenagers) with bags and enough fuel to be bladder challenging.
Personally after having flown it I don't want to fly anything else (apart from perhaps a SR22), for touring at least.
PostPosted:Sat Apr 02, 2011 12:33 pm
by Morley
Brilliant aircraft. Much better value than the 22. You can get a bells and whistles G2 glass Cockpit 20 for 120k. A 22, essentially the same with a bigger engine, is a lot lot more.
Having said that I have decided to do up my CW instead of upgrading. Engine this year (Nicholson Mclaren) and paint/interior next with poss avionics tweak too.
PostPosted:Tue Apr 05, 2011 8:43 am
by cmdr114b
Thanks for all the advice.
I definitely like all the bells & whistles so it would need to be a good spec.
I will keep looking around, to see what's available in the market.
PostPosted:Tue Apr 05, 2011 8:50 am
by Dave Phillips
I know of a mint condition 2006 glass model for sale. Only a couple of hundred hours. Don't know what the chap is asking but I can put you in touch.
PostPosted:Tue Apr 05, 2011 11:51 am
by Sharpie
Bloomer wrote:..If the t&c did not ban using her on grass (another silly rule) ...
Isn't that because of the wheel spats?
PostPosted:Tue Apr 05, 2011 12:25 pm
by scuderia
Sharpie wrote:Bloomer wrote:..If the t&c did not ban using her on grass (another silly rule) ...
No its beacause the pilots can't control their approach speed and arrive way to hot and snap them off.
Pretty much what G-BLEW said loved all my hours in Cirri 20 and 22.
Scud
PostPosted:Tue Apr 05, 2011 4:52 pm
by Morgan
Death Trap
Seriously, it's a great aircraft. Just do not overload it and do not take liberties with short runways on hot days
