By cmdr114b
#951130
I have been looking at the SR20 and wondered if anyone here as any experience of this plane.
Can you use it 4 up with limited fuel and baggage?
Anything not to like?
#951140
Runway and climb performance are lacking when loaded.
Nice enough but airframe really needs the bigger engine; don't know what the ratio is but suspect 20/22 is more thab 1:10.
By G-BLEW
#951142
Great aircraft, but take a look at w&b as 4 up + fuel + baggage will be interesting. Useful loads vary depending on equipment and tend to run between 360kg and 410kg. Check MAUW performance if you are based somewhere short.
Ian
By Pete L
#951187
On brief experience, the kit is amazing and it's the most wife-pleasing a/c of them all - very tempted with a share. But I preferred the C182 for it's air of brick sh*thouse and it's short field performance.
By Jonzarno
#951272
Which model (G1,G2 or G3) and which avionics package (ARNAV, Avidyne or Garmin Perspective) are you looking at?
By baldwinm
#951324
I fly a SR20 based at Blackpool (another part of the same group that Bloomer tried).
As stated there is a group rule on flying from grass - it does seem to need a lot of power to make headway when taxiing on grass but I would imagine dry, short (the grass not the runway length) grass should be fine.
It's the generation 3GTS version with all the toys (Avidyne, 2*GNS430W,Terrain, Traffic, STEC 55X autopilot, Stormscope). It will take my family (two slimmish adults & two teenagers) with bags and enough fuel to be bladder challenging.
Personally after having flown it I don't want to fly anything else (apart from perhaps a SR22), for touring at least.
By Morley
#951334
Brilliant aircraft. Much better value than the 22. You can get a bells and whistles G2 glass Cockpit 20 for 120k. A 22, essentially the same with a bigger engine, is a lot lot more.
Having said that I have decided to do up my CW instead of upgrading. Engine this year (Nicholson Mclaren) and paint/interior next with poss avionics tweak too.
By cmdr114b
#952042
Thanks for all the advice.
I definitely like all the bells & whistles so it would need to be a good spec.
I will keep looking around, to see what's available in the market.
By Sharpie
#952120
Bloomer wrote:..If the t&c did not ban using her on grass (another silly rule) ...
Isn't that because of the wheel spats?
By scuderia
#952134
No its beacause the pilots can't control their approach speed and arrive way to hot and snap them off.
Pretty much what G-BLEW said loved all my hours in Cirri 20 and 22.
Scud
By Morgan
#952242
Death Trap :twisted:
Seriously, it's a great aircraft. Just do not overload it and do not take liberties with short runways on hot days
